Exploring the Electron-Nucleus Dynamic
  • Thread starter sanjuro
  • Tags
    Dynamic
In summary, particles in the microscopic world, such as electrons, cannot fall into the nucleus due to the fundamental indeterminism of momentum and position. This is because the lowest energy state, known as the ground state, is the closest an electron can get to the nucleus. In neutron stars, the force of gravity can overcome the resistance of the electron to occupy a lower orbital, causing the electrons to either be gobbled up or annihilated. This is due to the collapse of the core, which involves endothermic reactions.
sanjuro
Newbie here, so go easy. Electrons are negatively charged bodies orbiting around the nucleus, which contains the proton and the neutron. The net charge of the nucleus is positive, so why is there no attracton between the electrons and the nucleus?
Hi Sanjuro,
I am a newbie too so my explanations won't be as accurate as other members of this board. But I intend to ask a lot of questions myself so I figure I should perticipate in answering some of the questions instead of just asking them :smile:
There is an attraction between the nucleus and the elections. And this attraction is what holds the atom together. And it is a stable, or balanced, attraction when the electrons equal the number of protons. And when the two parts do not equal each other the attraction is less stable.
For instance If an atom has 10 electrons, 10 Protons, and 10 Netrons, it is a stable atom and if the atom had feelings it would feel content. But if an atom had 11 electrons, 10 protons, and 10 netrons, it would feel discontent. The orbiting electrons would be pulling on the nucleus more than what the nucleus naturally felt comfortable with, and the atom would want to do something about its unbalanced state.
It could join up with another atom that was also feeling discontent but instead of the extra electron causeing the second atom to feel discontent let's say the second atom was missing a electron (making it positivly charged) and the two atoms could combine to form a compound.
Without going into the feelings of the particles involved, one can say simply that, yes, there is electrostatic attraction between nuclei and electrons, which is why atoms form.
The deeper question, which I assume you are simultaneously asking, is "if there is electrostatic attraction, why do the electrons not fall into the nuclei?"
The answer to this question is that, in the microscopic world, the fundamental indeterminism of momentum and position prohibits it. In short, when particles like electrons are in potential wells around nuclei, they cannot have any energy -- they can only have specific discrete energies. The lowest of these energies is call the ground state, and there is no way for an electron to get any closer, or have any lower energy, than the ground state. The electrons cannot fall any closer to the nucleus because there are no lower allowed energy states.
- Warren
While we're on the subject, how do the electrons get integrated into the nuclei in a neutron star? The force of gravity appearently overcomes the resistance of the electron to occupy an orbital that is lower than the ground state. But that is counterintuitive, since attempting to force the electron into the nucleus by crushing it should add energy to the system, moving the electrons into a higher orbital. I've never really understood the process behind this.
e- + p+ = n + νe
[edit: inverse neutron decay written correctly (thank you marcus)]
Bye, bye electron!
Since the electrons in a white dwarf (say) are already fully degenerate (they occupy all the energy levels allowed), if the (self) gravitational pressure become greater than the degeneracy pressure, where can they go?
Does anyone know whether, inside a white dwarf, the reaction is exothermic?
Originally posted by Nereid
e- + p+ + (anti)ν = n
Bye, bye electron!
would you be willing to look at this reaction as well?
e- + p+ = n + ν
it seems algebraically hardly any different from what you wrote and I know when a dead star collapses to neutron matter (for instance in supernova) a lot of neutrinos are produced
I think there may be an elementary argument showing that in a stable white dwarf core the reaction in question is not exothermic
While we're on the subject, how do the electrons get integrated into the nuclei in a neutron star? The force of gravity appearently overcomes the resistance of the electron to occupy an orbital that is lower than the ground state...
Somebody might ask Labguy, he knows the nuclear reactions involved in collapse of cores
Maybe one need not necessarily imagine, as you are doing, the electrons belonging to a certain nucleus being forced down into that individual nucleus
Perhaps one could imagine iron-sized nuclei being forced to fuse into nuclei of heavier elements and even into larger assemblages that one would not ordinarily call nuclei since they wouldn't have a stable existence normally
the merger of irons or anything heavier than iron is endothermic
(iron being the extremum of the curve of binding energy)
I'm not sure how the electrons get gobbled up or annihilated---Labguy would know at once, and there must be plenty on the web.
I believe that in the collapse of a dead star the core reactions are endothermic which is a key to the suddenness of the collapse. The fusion of iron to heavier stuff does not produce heat energy to fight the collapse, so once collapse starts nothing resists it
My hunch is that there are many reactions and some involve gobbling electrons while others involve emitting positrons---as the assemblages of baryons accumulate into pure neutron matter
either way the electrons get wiped out---either gobbled for breakfast or annihilated at brunchtime by the positrons. A huge storm of neutrinos is produced which is observed with SNe.
I realize I haven't answered your question but may hopefully have provided some grist for the mill, if I am mistaken let me know
Neutron stars form from protons and electrons via the inverse beta decay.
- Warren
IIRC, a neutron star forms from the core collapse of a sufficiently massive star, once it runs out of fuel (i.e. when there's only iron etc left in the core). A white dwarf forms when a core ceases to burn, and collapse is halted by (electron) degeneracy pressure. The star's mass is the key factor determining the fate - white dwarf, neutron star, black hole.
The piece of the puzzle I was missing (I looked it up) is how a core supported by electron degeneracy turns into a neutron core.
If it's still contracting, electrons are forced into higher and higher levels, until they enter the relativistic realm. Once they are energetic enough (0.8 MeV), the inverse beta reaction can take place. Bye, bye electrons.
Furthermore, the neutrinos carry away energy, cooling the core further. Highly endothermic. Quite a separate endothermic process from the breakdown of iron.
Thank you LURCH, a good question.
1. What is the electron-nucleus dynamic?
The electron-nucleus dynamic refers to the interaction between electrons and the nucleus of an atom. This interaction is governed by fundamental forces, such as electromagnetic force and nuclear force, and plays a crucial role in determining the properties and behavior of atoms.
2. How do electrons and the nucleus interact?
The interaction between electrons and the nucleus is primarily through the electromagnetic force. The positively charged nucleus and the negatively charged electrons attract each other, leading to a stable orbit of the electrons around the nucleus. Additionally, the nuclear force helps to hold the nucleus together despite the repulsive force between the positively charged protons.
3. What is the significance of exploring the electron-nucleus dynamic?
Exploring the electron-nucleus dynamic allows us to understand the fundamental nature of matter and the behavior of atoms. It also helps us to develop advanced technologies, such as nuclear energy and medical imaging, which rely on the properties of the electron-nucleus interaction.
4. How is the electron-nucleus dynamic studied?
The electron-nucleus dynamic can be studied through various techniques, such as spectroscopy, which involves analyzing the interaction between matter and electromagnetic radiation. Other methods include particle accelerators, which allow scientists to observe the behavior and properties of subatomic particles.
5. What are some current research areas in exploring the electron-nucleus dynamic?
Some current research areas include studying the behavior of electrons in extreme conditions, such as high magnetic fields and temperatures, which can provide insights into the fundamental forces at play. Additionally, researchers are also exploring the possibility of manipulating the electron-nucleus interaction to develop new materials and technologies.
  • Other Physics Topics
  • High Energy, Nuclear, Particle Physics
