Integrating u(t)^2: A Shortcut to Finding Fourier Coefficients?
In summary, the conversation discusses the evaluation of the integral \int_0^{2\pi}u^2(t)\mbox{d}t, where u(t)=2-\cos(t)+\sin(2t)- \cos(3t)+ \sin(4t). Several methods are suggested, including using Parseval's theorem and the Fourier Series of u(t). Ultimately, it is determined that the integral evaluates to 12\pi.
Mathitalian
28
Let [tex]u(t)=2-\cos(t)+\sin(2t)- \cos(3t)+ \sin(4t)[/tex]
Evaluate:
[tex]\int_0^{2\pi}u^2(t)\mbox{d}t[/tex]
Sorry, I don't have any idea :(... As I can see
is similar to the first term of Fourier Serie of the function u^2(t)...
You might consider using Parseval's theorem.
Likes 1 person
I don't see any reason to think about "Fourier Series" at all- just integrate directly:
[itex]\int_0^{2\pi} 4+ cos^2(t)+ sin^2(2t)+ cos^2(3t)+ sin^2(4t) dt[/itex]
is easy.
[itex]2\int_0^{2\pi}-2cos(t)+ 2sin(2t)- 2cos(3t)+ 2sin(4t)dt[/itex]
[itex]2\int_0^{2\pi}- cos(t)sin(2t)- cos(t)cos(3t)+ cos(t)sin(4t)dt[/itex]
[itex]2\int_0^{2\pi}-sin(2t)cos(3t)+ sin(2t)sin(4t)- cos(3t)sin(4t)dt[/itex]
You may need the trig identities for cos(a)cos(b), sin(a)sin(b), and sin(a)cos(b).
Likes 1 person
HallsOfIvy,
I think you just squared each term, rather than squaring the whole expression?
Likes 1 person
..along with the fact that ##u(t)## is its own Fourier Series.
Likes 1 person
Ok, thanks for your hints!
So
[tex]\int_{0}^{2\pi}u^2(t)\mbox{d}t= 12\pi[/tex]
right? :)
So
right? :)
Right. But if you think about orthogonality relations, you only have to evaluate the first integral Halls gave in post 3. The rest are obviously 0. And that one doesn't take much calculation either if you remember that the 'average value' of sin(nt)^2 or cos(nt)^2 where n>1 is 1/2.
Actually, you don't have to evaluate any integrals. The Fourier coefficients are sitting right there in the function u(t).
Sure, if you use Parseval's. I wasn't sure which track the OP was following.
What is an integral?
An integral is a mathematical concept that represents the area under a curve on a graph. It is used to calculate the total value of a function over a given interval.
What is a Fourier series?
A Fourier series is a mathematical representation of a periodic function as a sum of sine and cosine waves. It is used to break down complex functions into simpler components, making it easier to analyze and understand.
What is the difference between an integral and a Fourier series?
An integral calculates the total value of a function over an interval, while a Fourier series breaks down a function into simpler components. In other words, an integral gives the area under a curve, while a Fourier series gives the building blocks of a function.
Why are integral and Fourier series important in science?
Integral and Fourier series are important in science because they allow us to analyze complex functions and phenomena in a more manageable way. They are used in a wide range of fields such as physics, engineering, and signal processing to solve problems and make predictions.
What are some real-life applications of integral and Fourier series?
Some real-life applications of integral and Fourier series include analyzing the frequency components of sound waves, signal processing in telecommunications, and solving differential equations in physics and engineering problems.
