Integral help
so I'm working on a physics lab report, and I've derived the following formula
V=-N∫dB/dt(dot)dA
then I used the chain rule to turn it into
V=-N∫dx/dt * dB/dx(dot)dA
my question is, can I pull the dx/dt out of integral? I was doing the experiment, and measured the voltage drop, and varied the speed. the speed isn't constant, as it's the speed of a (frictionless) cart going down a ramp
'cause this formula ( V=-Nv∫dB/dx(dot)dA ) would be much better for my data anaylsis
Answers and Replies
tiny-tim
25,832
251
Welcome to PF!
Hi Son-of-Shem! Welcome to PF! :smile:
What is your A ? :confused:
You can pull the dx/dt outside the ∫ if it doesn't depend on your variable of integration (A) :wink:
thanks,
yeah... I should have mentiond that, shouldn't I... oops.
A is the area. I just wasn't sure since v depended on x, and there was a dx in there, if it was ok to pull that out...
tiny-tim
25,832
251
I'm completely confused …
I guessed A would be area, but area of what? :confused:
sorry, I'll start over from the beginning.
I send a cart with a magnet down a ramp, and through a coil of wire with 200 turns, sitting perpendicular to the tabletop, and measure the maximum volatage drop. The formula I found (using magnetic flux) is V=-N∫dx/dt * dB/dx(dot)dA
so A is the area of the coil.
if I can pull out dx/dt, then ∫dB/dx(dot)dA=-V/Nv, which is a measurable quantity :)
my question is: can I do that?
tiny-tim
25,832
251
Hi Son-of-Shem! :smile:
(just got up :zzz: …)
isn't A a constant? :confused:
why are you integrating?
yeah, it is constant...
I was trying to find voltage drop, which is -dΦ/dt
and dΦ=B(dot)dA
so Φ=∫B(dot)dA
so d/dt(∫B(dot)dA)=dΦ/dt
then V=-d/dt(∫B(dot)dA) (for a 1 turn coil)
or V=-d/dt(N∫B(dot)dA) (for coil w/ N turns)
and since area doesn't change with time...
then V=-N∫dB/dt(dot)dA
and by chain rule
then V=-N∫dx/dt * dB/dx(dot)dA
so V=-N∫v * dB/dx(dot)dA
my TA seemed to give the impression that the dB/dx term would interfere with my ability to remove v from the integral... that coupled with the fact that the velocity is actually changing (sqrt(2gh)) with x (height depends on x)
I believe that the magnetic field felt at the coil depends on the area of it, so the db/dx term can't be taken out...
Related Threads on Integral help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
