Integral \int_{1}^{\infty} \frac{1}{n^2+x^2}dx
  • Thread starter Theraven1982
  • Tags
    Integral
In summary: T.F.In summary, this person is trying to figure out the integral for a problem in which n doesn't go to infinity, but is a constant. They are having trouble finding an answer, and would appreciate any help.
Theraven1982
25
Hello,
I'm trying to calculate the following integral,
in the limit that n goes to infinity:
[tex] \int_{1}^{\infty} \frac{1}{n^2+x^2}dx [/tex]
I would be interested in the answer, but more in the way the answer can be obtained.
I'm rehearsing an old exam, but the first question is already a problem :(.
Any help would be greatly appreciated,
edit: i already looked on the internet, and in textbooks on how to accomplish this. But i only find integrals in which n doesn't go to infinity, but is a constant.
Integrate from 1 to t and then limit t to infinity. It's actually a pretty easy example :smile:
Perhaps this is more clear:
[tex]\int_{1}^{\infty} \frac{1}{n^2+x^2}dx[/tex]
If you can find the indefinite, just take the limit afterwards. You should think arctan-wise here...
Forgot to mention the following; in the problem it said the limit and integral should be interchanged.
I know the integral of
[tex] \frac{1}{(n^2+x^2)}=\frac{1}{a}ArcTan(x/a). [/tex]
But is this just 'it' ?
I was confused here for a second, I thought you had to use the limit for your boundary to go to infinity. So it's n that has to go infinity as well?
So you mean: [tex]\mathop {\lim }\limits_{n \to \infty } \int_1^\infty {\frac{1}
{{n^2 + x^2 }}dx} [/tex] ?
Yes, that's it!
And the limit and integral should be interchanged to solve this problem.
(btw: how do you get the graphics?)
Theraven1982 said:
Yes, that's it!
Well I see you already know how to write [tex]\LaTeX[/tex] code, just put it between [ tex ] [ /tex ] -tags, without the spaces then :wink:
Btw, I find 0 as answer, would that be correct?
I don't know if it is correct, i think when you would put it in mathematica, it'll give 0.
But why? It certainly makes sense, and the answer isn't unexpected... But how to prove it? Can you just fill in the following formula:
[tex] \int_{1}^{\infty} \frac{1}{(n^2+x^2)}=\frac{1}{a}ArcTan(x/a) [/tex]
This gives zero, but is this the way to go?
Well, I didn't use interchanging limit and integral, but I get 0 as well this way:
[tex]\begin{gathered}
\mathop {\lim }\limits_{n \to \infty } \left( {\int_1^\infty {\frac{1}
{{n^2 + x^2 }}dx} } \right) = \mathop {\lim }\limits_{n \to \infty } \left( {\mathop {\lim }\limits_{t \to \infty } \int_1^t {\frac{1}
{{n^2 + x^2 }}dx} } \right) = \mathop {\lim }\limits_{n \to \infty } \left( {\mathop {\lim }\limits_{t \to \infty } \left[ {\frac{1}
{n}\arctan \left( {\frac{x}
{n}} \right)} \right]_1^t } \right) \hfill \\ \\
= \mathop {\lim }\limits_{n \to \infty } \left( {\mathop {\lim }\limits_{t \to \infty } \left( {\frac{1}
{n}\arctan \left( {\frac{t}
{n}} \right) - \frac{1}
{n}\arctan \left( {\frac{1}
{n}} \right)} \right)} \right) = \mathop {\lim }\limits_{n \to \infty } \left( {\frac{\pi }
{{2\left| n \right|}} - \frac{1}
{n}} \right)} \right) = 0 \hfill \\
\end{gathered} [/tex]
Both the integral and the limit should be uniformly convergent, so you can interchange the two. Definite integral over zero is always zero.
Yes, this is just the way of filling in the integral; but i don't know what changes when you first take the limit. You could equally well take the n^2 outside of the integral:
[tex] \int_{1}^{\infty} \frac{1}{n^2}\frac{1}{1+(x/n)^2} [/tex]
from which it can also be seen.
But maybe i should be satisfied with this
So you just say: if n goes to infinity, the formula goes to zero, and therefore the integral goes to zero?
edit
Thanks to all who replied; really appreciated.
W.
1. What is the purpose of the integral \int_{1}^{\infty} \frac{1}{n^2+x^2}dx?
The integral \int_{1}^{\infty} \frac{1}{n^2+x^2}dx is used to calculate the area under the curve of the function f(x) = \frac{1}{n^2+x^2} from x = 1 to x = ∞.
2. What is the significance of the limits of integration being 1 and ∞?
The lower limit of integration being 1 indicates that the area under the curve is being calculated starting from x = 1. The upper limit being ∞ means that the area is being calculated up to infinity, indicating that the curve never ends and continues indefinitely.
3. How is this integral related to calculus?
This integral is a fundamental concept in calculus, specifically in the branch of integration. It is used to find the area under a curve and is a key concept in understanding the relationship between a function and its derivative.
4. Is this integral solvable?
Yes, this integral can be solved using various techniques such as substitution, integration by parts, or using trigonometric identities. The result will be a finite value, indicating that the area under the curve is finite.
5. What are the applications of this integral in real-world problems?
This integral has various applications in physics, engineering, and other fields where calculations involving areas under curves are necessary. For example, it can be used to calculate the work done by a force, the displacement of a particle, or the voltage in an electrical circuit.
  • Calculus
  • Calculus
