Integral notation question
In summary: All I mean is that in Fourier Analysis, or really in general, sometimes there are very good reasons to change the variable of integration so as not to confuse it with other variables.
ognik
643
Hi, doing Fourier series and noticed that with period $2\pi$ the coefficient formula integrates w.r.t. x (for f(x))
However adjusting for f(x) with period 2L, they write, for example: $ a_n=\frac{1}{L} \int_{-L}^{L}f(t) Cos \frac{n\pi t}{L} \,dt $. Why use that intermediate variable?
I have also noticed something similar elsewhere, where the limit(s) is $\inf$, they write $\int f(x)dx$ something like $ \lim_{{s}\to{\inf}}\int_{-s}^{s}f(s) \,ds $, again why please?
It doesn't seem to affect the final answer ever?
Probably because, in the context of Fourier analysis, you might have $x$'s floating around as well, and you don't want to be tempted to take $x$'s out of the integral if it's illegal.
It can affect the answer if you're dealing with discontinuities, and you have to take the Cauchy Principal Value.
Not sure I get that, they seem to replace ALL x's in the eqtn with t? While Fourier series can be applied to discontinuous functions, in this eqtn that is not known, the eqtn would apply to continuous functions as well...
Good link, thanks. I'll have to go back and check my book's usage when time, but to confirm - this implies to use this technique when there would be, for example, discontinuities at $ \pm \infty $, hence we use limits to get an answer?
I have an example using what I think, that you might like to comment on: $ f(x)=\left\{ -\frac{1}{2}(\pi + x), -\pi \le x \lt 0 \right\}, \left\{ \frac{1}{2}(\pi - x), 0 \lt x \le \pi \right\} $
(BTW, how do I have more than 1 line inside the {}?)
This is an odd function, so $a_n$=0, $ b_n = \frac{1}{\pi}\int_{-\pi}^{\pi}f(x)Sin (nx) \,dx $
The discontinuity at 0 means I need an intermediate variable, so $ b_n = \lim_{{t}\to{0}} \frac{1}{\pi} [\int_{-\pi}^{t}f(x)Sin (nx) \,dx + \int_{t}^{\pi}f(x)Sin (nx) \,dx] $
$ = \lim_{{t}\to{0}} \frac{1}{2\pi} [-\int_{-\pi}^{t}(\pi + x)Sin (nx) \,dx + \int_{t}^{\pi} (\pi-x) Sin (nx) \,dx] $
Is that correct use of the intermediate variable t? (also is my Fourier correct so far?)
While looking at this example further, the book gives an answer of $ f(x)= \sum_{n=1}^{\infty} Sin\left(\frac{nx}{n}\right) $ ... that must be a typo, I get $ f(x)= \sum_{n=1}^{\infty} \frac{1}{n} Sin\left({nx}\right) $?
All I mean is that in Fourier Analysis, or really in general, sometimes there are very good reasons to change the variable of integration so as not to confuse it with other variables. For example, in PDE's, if you're doing Fourier Analysis, and you want to write your final answer down in all its glory, you're really going to want your Fourier integrals not to be using a variable of integration that is one of the ultimate independent variables. In the http://mathhelpboards.com/potw-university-students-34/problem-week-182-september-22-2015-a-16370.html, the solution to the pde is
$$u(x,t)=\sum_{n=1}^{\infty}\left(a_n \sin\left[(n\pi)^2 t\right]+b_n \cos\left[(n\pi)^2t\right] \right) \sin(n\pi x),$$
where
\begin{align*}
a_n&=\frac{2}{(n\pi)^2} \int_0^1 g(x) \, \sin(n\pi x) \, dx \\
b_n&=2\int_0^1 f(x) \, \sin(n\pi x) \, dx.
\end{align*}
Now really, if I want to write this as one glorious equation, I'm not going to use $x$'s in the $a_n$ and $b_n$ equations. Nor, really, am I going to use $t$'s. Those are the two independent variables in the original PDE. I might use a greek letter like $\xi$. So the final answer would be
$$u(x,t)=\sum_{n=1}^{\infty}\left(\frac{2}{(n\pi)^2} \int_0^1 g(\xi) \, \sin(n\pi \xi) \, d\xi \cdot \sin\left[(n\pi)^2 t\right]+2\int_0^1 f(\xi) \, \sin(n\pi \xi) \, d\xi \cdot \cos\left[(n\pi)^2t\right] \right) \sin(n\pi x).$$
Now, you see, if I decided I wanted, for some reason, to pull the $\sin(n\pi x)$ into the integrals, I could do that with no confusion. Dummy variables are dummy variables. You can use whichever one you want. Just don't let it get mixed up with any other variables outside the little world of the integral.
Or there are a couple other cases where you might need it, but yes.
Plot this function.
Not all discontinuities require this sort of treatment. Your discontinuity is a simple jump discontinuity. You do need to break up your integral into two regions, but using variables in the limits isn't necessary. The reason you know that is because the integrals you get, when you simply break it up into two regions, converge. They exist. Hence, no need for variables in the limits.
Probably. You can confirm with Wolfram|Alpha.
1. What is integral notation?
Integral notation is a mathematical notation used to represent the concept of integration, which is the inverse operation of differentiation. It is used to calculate the area under a curve or the accumulation of a continuous quantity over a specific interval.
2. How is integral notation written?
Integral notation is written using the integral symbol (∫) followed by the function to be integrated and the variable of integration. The integral symbol is placed in front of the function and the variable of integration is written at the end of the integral symbol.
3. What does the integral symbol (∫) mean?
The integral symbol (∫) represents the operation of integration. It is a stylized letter "S" that stands for "sum" and indicates that the function following it should be integrated.
4. What is the purpose of integral notation?
The purpose of integral notation is to provide a concise and standardized way of representing the operation of integration in mathematics. It allows for complex calculations to be written in a more compact and manageable form, making it easier to solve problems related to calculating areas and volumes.
5. What are some common applications of integral notation?
Integral notation is commonly used in physics, engineering, economics, and other fields to solve problems related to finding the area under a curve, calculating volumes, and determining average values of continuous functions. It is also used in calculus to find antiderivatives and solve differential equations.
  • Calculus
