Integral of 1/(sqrt(x)-x)
  • Thread starter beanryu
beanryu
92
integrate 1/(sqrt(x)-x)
1st I tried to do it the "regular" way, I know that it must be the derivative of
ln(sqrt(x)-x), but the derivative of sqrt(x)-x is not 1. So I added stuff to the equation to make it like 1/(sqrt(x)-x) = ((1/2)(x)^(-1/2)-(1/2)(x)^(-1/2)-1+2)/(sqrt(x)-x)... and more things goes on and I got something like (4*sqrt(x)-1)/(2*(x-x*sqrt(x)))... which is obviously not the answer.
2nd I tried to use t = sqrt(x) and 1/(sqrt(x)-x) = dt^2/(t-t^2), but I have no idea how to solve this...
Answers and Replies
rocomath
1,755
is your problem?
[tex]\int\frac{dx}{\sqrt{x}-x}[/tex]
beanryu
92
yeah
morphism
2,017
If t=sqrt(x), then dt/dx=1/(2sqrt(x))=1/(2t). So your integrand should become 2t/(t-t^2). It should be pretty easy to take it from here.
Avodyne
90
When you have the square root of something in an integral, it's offen helpful to make the substitution u2 = thing that's under the square root sign.
transgalactic
1,395
is the answer :
2* ln(1-x^2) +c
CompuChip
4,309
49
transgalactic = beanryu?
And did you try differentiating it and check what comes out?
transgalactic
1,395
i tried the method of
x=v^2
it gives me that answer
2* ln(1-x^2) +c
beanryu is it the right answer??
PowerIso
329
x=v^2
2* ln(1-x^2) +c
Take the derivative and if you get the same thing that is in your integral, you are right.
transgalactic
1,395
unfortunatly no
but where i did wrong
{ is integral sign
i
made x=v^2 >>> dx=2v*dv
then it gives us
{ (2v*dv)/(v-v^2) that gives us
{ 2*dv/(1-v) = 2*ln(1-v) = 2*ln(1-x^2)
Avodyne
90
1) The integral of dv/(1-v) is NOT ln(1-v). (Close, but not quite. Hint: if you define u=v-1, what do you get?)
2) v is NOT equal to x^2.
transgalactic
1,395
its -ln(1-v)
right??
what do meen v is not equal to x^2
i defined that
CompuChip
4,309
49
No, you defined v^2 = x.
What does that make v?
(By the way, you're correct on the -ln(1-v) now)
transgalactic
1,395
aaaaaaaahhhhhhhhh
damn little mistakes
beanryu
92
if x=v^2 >>> shouldn't dx = d(v^2)?
beanryu
92
i got the answer,
my answer is (-2)ln(sqrt(x)-1) using u^2 = x method,
than the answer in the textbook is (-2)ln(1-sqrt(x)),
I took both derivativea they are the same... wierd...
if dx/(sqrt(x)-x) = dy/(tan(y)), should I use answer (-2)*ln(1-sqrt(x)), because this is the function of x when x<1.
thank you guys~
transgalactic
1,395
dx = d(v^2)=2v*dv
Suggested for: Integral of 1/(sqrt(x)-x)
  • Last Post
  • Last Post
  • Last Post
  • Last Post
