Homework Help: Integral of ln
  1. Jul 2, 2012 #1
    [itex]f(x)=\int\frac{x+1}{x^2+2x}[/itex]
    3. The attempt at a solution
    I know that this can be solved with substitution. I'm wondering why I get the wrong answer when using this other method...
    [itex]=\int\frac{x}{x^2+2x}+\frac{1}{x^2+2x}[/itex]
    [itex]=\int\frac{1}{x+2}+\int\frac{1}{x^2+2}[/itex]
    [itex]=ln(x+2)+ln(x^2+2) + c[/itex]
    I could simplify more, but it's wrong. It should be [itex].5(x^2+2) + c[/itex]
    I'm guessing that [itex]\int\frac{1}{x^2+2}\neq ln(x^2+2)[/itex] so in what cases does [itex]\int \frac{1}{x} = ln(x) + c[/itex] not hold?? I just learned this stuff today so any answers will have to be rather explicit please.
  3. Jul 2, 2012 #2
    This.
    d/dx ln(x2+2) = 2x/(x2+2), which is obviously not equal to 1/(x2+2). Never forget the chain rule.
    To integrate 1/(x2+2), you need to use trigonometric substitution.
  4. Jul 2, 2012 #3
    Don't know that yet. So I guess that any time there's a nested function then ∫(1/x) dx=ln(x)+c doesn't hold?
  5. Jul 2, 2012 #4
    Do you know of the chain rule?
  6. Jul 2, 2012 #5
    SammyS
    Staff Emeritus
    Of course [itex]\displaystyle \int \frac{1}{x}\,dx=\ln|x|+C[/itex] always holds.
    What doesn't hold in general is [itex]\displaystyle \int \frac{1}{f(x)}\,dx=\ln|f(x)|+C[/itex]
  7. Jul 2, 2012 #6
    Yes, I meant I don't know trig substitution.
  8. Jul 2, 2012 #7
    Could you provide a few examples please?
  9. Jul 2, 2012 #8
    Mark44
    Staff: Mentor
    You did this problem the hard way, by splitting in into two integrals. An easy substitution will do the trick.
    Let u = x2 + 2x, so du = (2x + 2)dx
    Notice any similarity to the numerator of your original integral?
  10. Jul 2, 2012 #9
    Dick
    It's not a trig substitution. It's a u substitution. Try putting u=x^2+2x. What is du?
  11. Jul 2, 2012 #10
    To the above two posts -
    I know it's not trig substitution, I only mentioned I don't know that because it was mentioned by someone else. U-sub is easy, but I was trying to solve it this way because I'm trying to get a handle on derivatives and integrals of ln(x)
  12. Jul 2, 2012 #11
    Dick
    If you don't want to do it the easy way using U-sub, then you'll need to do partial fractions on the second integral. Do you know that?
  13. Jul 2, 2012 #12
    Or complete the square and use a trig substitution?
  14. Jul 2, 2012 #13
    Dick
    If doing it the hard way isn't enough and you want to do it the REALLY hard way, that should work.
  15. Jul 3, 2012 #14
    SammyS
    Staff Emeritus
    For instance, if f(x) = x2, then
    [itex]\displaystyle \int \frac{1}{f(x)}\,dx=\int\frac{1}{x^2}\,dx=\int x^{-2}\,dx=-x^{-1}+C\ne\ln(x^2)+C[/itex]
  16. Jul 3, 2012 #15
    Mentallic
    [tex]\int\frac{1}{x}dx=\ln|x|+c[/tex] only holds because [tex]\frac{d}{dx}\left(\ln|x|+c\right)[/tex][tex]=\frac{1}{x}\cdot \frac{d}{dx}(x)=\frac{1}{x}[/tex] by use of the chain rule, while, in general, [tex]\frac{d}{dx}\left(\ln|f(x)|+c\right)[/tex][tex]=\frac{1}{f(x)}\cdot\frac{d}{dx}f(x)=\frac{f'(x)}{f(x)}[/tex]
    So if you have some f(x) in the denominator that needs integrating, unless the numerator is the derivative of the denomintor (or at least a constant multiplied by the derivative) then you can't take the log.
