Integral Problem
  1. Aug 30, 2007 #1
    [tex]\int\frac{dx}{cos(x)-1}[/tex]
    2. Relevant equations
    None
    3. The attempt at a solution
    I've had extreme problems in even attempting to begin this problem. I initially tried to multiply by the conjugate to get int[(cosx+1)/(cos^2(x)-1)], but this doesn't seem to be leading me anywhere.
    Since then, I've tried looking for a possible substitution to make, but have been coming up blank. Using the search function on physics forums I found a similar problem in which the substitution u=tan(x/2) was suggested. However I have not been able to figure out if (or how) this same substitution would apply in this case.
  3. Aug 30, 2007 #2
    Can you simplify cos2(x)-1 at all?
  4. Aug 31, 2007 #3
    let u = cosx - 1
    now tell me what you get when you substitute
  5. Aug 31, 2007 #4
    um... cos^2(x)-1 = -sin^2(x)...
    int[cotxcscxdx] - int[csc^2(x)]
    -cscx + cotx?
    Or did I drop something somewhere? (which is quite possible)
  6. Aug 31, 2007 #5
    How to Exit Trigonometry
    the substitution u=tan(x/2) is a great suggestion, I was about to recommend it!
    I don't know the proof in it's entirety but here are the formula's:
    This can only be used if you have ONLY trig functions along with *, /, +, - a constant, if you have a ln (x), e^x, etc... you have to find another way.
    [tex]
    tan(\frac{x}{2}) = y [/tex] then:
    [tex]
    sin(x) = \frac{2y}{1+y^2}
    [/tex]
    [tex]
    cos(x) = \frac{1-y^2}{1+y^2}
    [/tex]
    [tex]
    dx = \frac{2dy}{1+y^2}
    [/tex]
    This method to "Exit Trigonometry" is unbelievably helpful I think.
    These formula's are nicer, but there's a catch. They only work on EVEN powers with respect to sin and cos.
    [tex]
    tan (x) = y
    [/tex]
    [tex]
    sin^2 (x) = \frac{y^2}{1+y^2}
    [/tex]
    [tex]
    cos^2 (x) = \frac{1}{1+y^2}
    [/tex]
    [tex]
    cos(x)sin(x) = \frac{y}{1+y^2}
    [/tex]
    [tex]
    dx = \frac{dy}{1+y^2}
    [/tex]
  7. Aug 31, 2007 #6
    I think you missed a minus sign. You should have the integral of (cos(x)+1)/(-sin2(x))=-(csc(x)cot(x)+csc2(x)).
  8. Aug 31, 2007 #7
    ima go ahead and show some of my work (practicing latex) so ur in luck
    [tex]\int\frac{dx}{\cos{x}-1} \ \ \ \ \ u=\cos{x}-1 \ \ \ \ \ -\csc{x}du=dx[/tex]
    [tex]-\csc{x}\int\frac{du}{u}[/tex]
    integrating
    [tex]-\csc{x}\ln{|\cos{x}-1|}+C[/tex]
    it can also be written as (power rule)
    [tex]\ln{|\cos{x}-1|}^{-\csc{x}}+C[/tex]
    differentiating to check work
    [tex]\frac{-\csc{x}(-\sin{x})}{\cos{x}-1}[/tex]
  9. Aug 31, 2007 #8
    You can not pull functions of x outside of an integral like that. So from the very start this is the wrong way to a solution.
    Your integral is correct, but since it was based on a false premise of being able to pull out the cosecant function it will not give the correct answer to this problem.
    How did you differentiate this? You either didn't use the chain rule correctly, or did not use the product rule correctly because that is not the derivative you should end up with.
  10. Aug 31, 2007 #9
    lol ... my baddd, it's been 2 days since i've gotten back into Calculus ... damn
    edit: ok i re-did it, the last part i understand why it was incorrect, the check i forgot the product rule, the first part i don't get.
  11. Aug 31, 2007 #10
    hehe at least you didn't do that on a test :s
    @just_see try using the substitutions I posted. of the top formulas all you need is cos (x) and dx, well tan x/2 = y also to go back to x when you're done integrating.
  12. Aug 31, 2007 #11
    is this a Cal 2 problem? i do not remember learning any of those things you posted bob.
  13. Aug 31, 2007 #12
    You can't pull a function of x outside of an integral with respect to x. dx is part of that integral, and after you made your substitution you factored part of it outside of the integral, that isn't allowed.
    du=-sin(x)dx, however you don't have a sin(x) in the original integral. The goal is to do some work on the original expression so that you CAN transform dx into du.
  14. Aug 31, 2007 #13
    so the only things i can pull outside of an integral are constants, gotcha.
  15. Aug 31, 2007 #14
    Those formula's aren't usually taught nowadays. I heard years ago they were stressed in high school but not now :/.
    In my Calc book (Stewart) they're not shown explicitly, the derivation is given as one of the problems in some chapter so nobody really pays attention.
    My Calc 2/3 teacher uses those formula's all the time. If there's no formula to reduce to a nice trig function then just "Exit Trigonometry".
  16. Aug 31, 2007 #15
    Gib Z
    We know that [tex]\tan (2x) =\frac{2 \tan x}{1- \tan^2 x}[/tex]
    Letting x=y/2, [tex]\tan y = \frac{2\tan (y/2)}{1-\tan^2 (y/2)}[/tex].
    And again, let t= tan (y/2)
    [tex]\tan y = \frac{ 2t}{1-t^2}[/tex].
    To get the expressions for sine and cosine of y, we draw A right angled triangle, with one of the acute angles being y. Then we know the opposite side is 2t, and the adjacent side is 1-t^2. By Pythagoras, the hypotenuse is 1+t^2. Its simple to see what sin and cos y are from that.
    As for the derivative:
    Using the chain rule and Trig Pythagorean identities;
    [tex] \frac{d}{dx} \tan (x/2) = \frac{1}{2} \sec^2 (x/2) = \frac{1}{2} (\tan^2 (x/2) + 1) = \frac{t^2+1}{2}[/tex] so the expression for dx follows.
Similar Discussions: Integral Problem
  1. Integration problem (Replies: 4)
  2. Integral Problem (Replies: 31)
  3. Integration problem (Replies: 9)
  4. Integration Problem (Replies: 7)
Loading...
