Evaluating Integral: \int_0^\infty\frac{x^{3}}{e^x-1}dx
  • Thread starter vabamyyr
  • Tags
    Integral
I am sorry saltydogoh, I am sorry saltydogNo problem, no need to apologize! I just wanted to clarify what I meant. And thank you for the explanation, it makes sense now.
vabamyyr
66
im havin trouble evaluating integral [tex]\int_0^\infty\frac{x^{3}}{e^x-1}dx[/tex]
i tried integrating by substitution but got nowhere. if there wasnt factor -1 it would equal G(4) which is 3! but first integral equals pii^4/15 which is 6,49...
But any hint how to do this integral?
Expand [tex] \frac{1}{e^{x}-1} [/tex] into series and part integrate.
Daniel.
You could expand it to a series or you could integrate that and then take the limit. This will require integration by parts, but the tabular method will make it less messy with trying to work out the different "u's" and "dv's".
[tex]\int_0^\infty\frac{x^{3}}{e^x-1}dx = \lim_{b\rightarrow\infty}\int_0^{b}\frac{x^{3}}{e^x-1}dx[/tex]
Jameson
[tex]\int_0^\infty\frac{x^{3}}{e^x-1}dx = \lim_{b\rightarrow\infty}\int_0^{b}\frac{x^{3}}{e^{x}-1}dx=6(lix - xlix+0.5x^{2}lix+\frac{1}{6}x^{3}ln(1-e^{x})-\frac{1}{4}x^{4}+C[/tex] from 0 to b [tex]lix=\int\frac{dx}{lnx}[/tex] from 0 to infinity but i have trouble evaluating that too
i tried ur idea as well dextercioby by trying to expand [tex] \frac{1}{e^{x}-1} [/tex] i figured out that [tex]{e^{x}-1}=\Sigma_{1}^{\infty}\frac{x^k}{k!}[/tex]
but got stuck with [tex] \frac{1}{e^{x}-1} [/tex]
I told you how to do it.This is the famous Debye-Einstein integral.
[tex] \mathcal{D}_{3}=\int_{0}^{\infty} \frac{x^{3}}{e^{x}-1} \ dx=\int_{0}^{+\infty} \frac{x^{3}e^{-x}}{1-e^{-x}} \ dx=...=\sum_{n=1}^{\infty} \int_{0}^{\infty} x^{3}e^{-nx} \ dx =\Gamma (4)\zeta (4) [/tex]
Daniel.
it is getting over my head, i think ill have to learn more before doing that task
[tex] \frac{1}{1-e^{-x}} =\sum_{n=0}^{\infty} e^{-nx} [/tex]
is all you need.
Daniel.
thx dextercioby, i learned little about Riemann zeta function and now i see where pi^4/15 comes from
Daniel.
Thanks Daniel. Interesting problem and approach. Took me a while to figure it out:
[tex]\sum_{n=1}^{\infty} \int_{0}^{\infty} x^{3}e^{-nx} \ dx =\sum_{n=1}^{\infty}\frac{6}{n^4}[/tex]
For the sum, Mathematica returns:
[tex]=\frac{\pi^4}{15}[/tex]
As far as:
[tex]\sum_{n=1}^{\infty}\frac{6}{n^4}=\Gamma (4)\zeta (4) [/tex]
Suppose I can dig into those too. :smile:
Edit: Alright, I don't know why I got the Zeta function mixed up with a sum of primes. :blushing:
Nevermind.
Edit2: Here embrass me:
[tex]\zeta(n)=\sum_{k=1}^{\infty}\frac{1}{k^n}[/tex]
IS the Zeta function dude!
And:
[tex] \Gamma(4)=6[/tex]
there are several shapes to express zeta function and u don't have to tell me what gamma function is
Nevermind.
It can be expresssed as a certain product over primes, you could have been thinking of that.
One comment I'd like to make is about the ... in Daniel's post. This is leaving out the important technical bit of justifying switching the infinite sum with the integral (which isn't always valid, but is here of course). I'm sure he's aware of this, but anyone trying to fill in the ... should keep this in mind.
Vabamyyr, sorry you mis-understood my comments: I was saying that to me. :yuck: Not you. You knew it before me.
Hope you understand. :smile:
You know, if EvLer see's this he's gonna' make me do some problems. :yuck:
Shmoe, could you explain the ...? and maybe show a case when it's not possible.
I believe its:
If the sequence of functions:
[tex]\sum_{n=1}^{\infty}f_n(x)[/tex]
converges uniformly to a function f(x) then:
[tex]\int_a^b \sum_{n=1}^{\infty} f_n(x)dx=\sum_{n=1}^{\infty} \int_a^b f_n(x)dx[/tex]
If so, then one would need to show uniform convergence for the series:
[tex]\sum_{n=1}^{\infty}\frac{x^3}{e^{nx}}[/tex]
Someone I hope will correct me if I'm wrong.
[tex]\int_{0}^{\infty} \sum_{n=1}^{\infty} x^{3}e^{-nx} \ dx=\sum_{n=1}^{\infty} \int_{0}^{\infty} x^{3}e^{-nx} \ dx[/tex]
is the step I'm talking about. There was a recent post about dominated convergence if you want some details about this.
A series is really just a sequence of functions, so for an example that fails I'll give a sequence of functions where swapping the limit and integral fails. Let [tex]f_n(x)[/tex] be 1/n on [0,n] and zero everywhere else. Then [tex]f_n\rightarrow f(x)[/tex] where f(x)=0 everywhere (this convergence is even uniform). Now:
[tex]\int_{0}^{\infty} \lim_{n\rightarrow\infty}f_n(x)dx=\int_{0}^{\infty} f(x)dx=0[/tex]
but
[tex]\lim_{n\rightarrow\infty}\int_{0}^{\infty} f_n(x) dx=\lim_{n\rightarrow\infty}\int_{0}^{n} \frac{1}{n} dx=\lim_{n\rightarrow\infty} 1 =1[/tex]
You know Vabamyyr, someone oughta' tell me: "you know Salty, for not seeing that, for punish work, you need to work through Euler's original computation of [itex]\zeta(2)[/itex]. That's right, all the steps. And don't use Mathematica neither!"
Edit: "and while you're at it, figure out this one too:"
[tex]\sum_{k=1}^{\infty} \frac{1}{k^{2n}}[/tex]
for all natural numbers n.
1. What is the purpose of evaluating this integral?
The purpose of evaluating this integral is to find the exact numerical value of the area under the curve of the function f(x) = x^3/(e^x-1) on the interval [0, ∞). This can be useful in solving various problems in mathematics, physics, and engineering.
2. Is this integral solvable by hand?
No, this integral is not solvable by hand as it involves a complex function with no known antiderivative. It can only be evaluated using numerical methods or approximations.
3. How can this integral be evaluated numerically?
This integral can be evaluated numerically using techniques such as the trapezoidal rule, Simpson's rule, or Monte Carlo integration. These methods approximate the area under the curve by dividing it into smaller, simpler shapes and calculating their individual areas.
4. What is the significance of the infinite upper limit in this integral?
The infinite upper limit indicates that the function f(x) has an infinite area under the curve on the interval [0, ∞). This can be interpreted as the function approaching infinity as x approaches infinity.
5. Can this integral be used to solve real-world problems?
Yes, this integral can be used to solve various real-world problems in fields such as thermodynamics, statistical mechanics, and quantum mechanics. For example, it can be used to calculate the total energy of a black body or the average energy of particles in a gas.
  • Calculus
