1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Integral question
  1. Oct 7, 2009 #1
    Evaluate the following:
    Integral of 2x/(1-x^4) dx with lxl<1
    3. The attempt at a solution
    I tried to use long division to solve the question, then got:
    2x/(1-x^4) = (2x^5)/(1-x^4) + 2x
    S (2x^5)/(1-x^4) + 2x dx
    this is where I seem to be stuck on..
    do I use chain rule of letting u = (1-x^4)?
    thank you in advance
    2. Relevant equations
  3. Oct 7, 2009 #2
    Try letting u = x2 and then substitute in the original integrand.
  4. Oct 7, 2009 #3
    You can also try using the following identity:
  5. Oct 7, 2009 #4
    Staff: Mentor
    This doesn't make any sense at all. I have no idea how you ended up with that result.
  6. Oct 7, 2009 #5
    It's called "partial fractions". If you are expected to do this kind of problem, you should have already seen that. [itex]1- x^4= (1- x^2)(1+ x^2)= (1- x)(1+ x)(1+ x^2) so the fraction can be written
    [tex]\frac{2x}{1- x^4}= \frac{A}{1- x}+ \frac{B}{1+ x}+ \frac{Dx+ C}{1+ x^2}[/tex]
    There are a number of different wasy of determing the values of A, B, C, and D from that. For example, if you multiply both sides of the equation by [itex]1- x^4[/itex] you get a polynomial equation that must be true for all x. Setting corresponding coefficients equal will give you four equations for A, B, D, and D. More simply, taking x= 1, -1, 0, and, say, 2 will give you four equations.
    However, Bohrok's suggestion of substituting u= x2 first is simpler. Once you have it reduced to
    [tex]\int \frac{du}{1- u^2}[/tex]
    you can use "partial fractions" to write it as
    [tex]\int \frac{Adu}{1- u}+ \int \frac{Bdu}{1+ u}[/tex]
  7. Oct 7, 2009 #6
    Or, if you've covered the hyperbolic functions and to make the answer neater, you could use tanh-1u in getting your answer.
  8. Oct 7, 2009 #7
    Thank all of you for your help.
    I haven't learned partial fractions yet so I tried Bohrok's way by letting x^2 = u
    This is what I got for answer:
    arctan(-x^2) is it right?
    I had trouble with solving 1/(1-u^2).. so i just did integral to tan, am I allowed to?
  9. Oct 7, 2009 #8
    That's close. ∫1/(1-u2) du = tanh-1u + C
    Then put the integral back in terms of x.
Similar Threads - Integral question Date
Calculus 2 - Trig Integrals Question (Integrating cos^2x) Feb 8, 2018
Integration question Jan 15, 2018
Easy matrix integration question Dec 20, 2017
