Integral Question: ∫(sec^2 x tanx) dx from 0 to ∏/3
  • Thread starter LocalStudent
  • Tags
    Integral
In summary, the conversation discusses the integral ∫(sec^2 x tanx) dx from 0 to ∏/3 and the attempt to solve it using integration by parts. It is noted that there is a direct u-sub method to handle the integral, but the method used illustrates an important concept. The concept is that when performing integration by parts, the resulting integral may lead back to the original question, which can be solved using the equation I = B/2. This type of oscillatory behavior is important for many trigonometric and exponential integrals. The conversation concludes with the realization that this exact question came up in the math test.
LocalStudent
∫(sec^2 x tanx) dx
the integral is from 0 to ∏/3
I tried using integration by parts
When I did integration by parts I got to this:
tan^2 x - ∫(sec^2 x tanx) dx (integral also from 0 to ∏/3)
which take you back to the question I started with.
Hint: Are there trigonometric identities that relate [itex]sec^{2}x[/itex] and [itex]tan^{2}x[/itex]?
There is a direct u-sub to handle this integral, but the way you have done it does illustrate an important concept.
Suppose, I = ∫Adx and you perform integration by parts and get I = B - ∫Adx. Well, that second integral is, as you noted, what you started with. Thus, I = B - I and so 2I = B and thus, I=B/2.
That type of oscillatory behavior is very important for many trigonometric and exponential integrals.
integrals.
Thanks, that was really helpful. I hope I remember and notice it in my test.
Thanks again! This exact question came up in my math test :)
1. What is the equation for "Integral Question: ∫(sec^2 x tanx) dx from 0 to ∏/3"?
The equation is ∫(sec^2 x tanx) dx from 0 to ∏/3.
2. How do you solve the integral for "Integral Question: ∫(sec^2 x tanx) dx from 0 to ∏/3"?
To solve this integral, use the trigonometric identity sec^2 x = 1 + tan^2 x and then use substitution to change the integral into the form ∫(1 + tan^2 x) tanx dx. Then, use integration by parts to solve the integral.
3. What is the value of the integral for "Integral Question: ∫(sec^2 x tanx) dx from 0 to ∏/3"?
The value of the integral is approximately 0.75.
4. Can you explain the steps to solving "Integral Question: ∫(sec^2 x tanx) dx from 0 to ∏/3"?
First, use the trigonometric identity sec^2 x = 1 + tan^2 x to change the integral into the form ∫(1 + tan^2 x) tanx dx. Then, use u-substitution with u = tanx and du = sec^2 x dx to change the integral into the form ∫(1 + u^2) du. Use integration by parts with u = u and dv = 1 + u^2 to solve the integral. Finally, substitute back in u = tanx and solve for the limits of integration to get the final answer.
5. What is the significance of the limits of integration in "Integral Question: ∫(sec^2 x tanx) dx from 0 to ∏/3"?
The limits of integration, 0 and ∏/3, determine the range of values for x in the integral. In this case, the integral is being solved from 0 to ∏/3, which means that the area under the curve is being calculated within that specific range. It is important to have accurate limits of integration to get the correct value for the integral.
