Integral sqrt(x)*e^-x
Evaluate the following integral:
0 √(x)* e-x dx
0 e-x2 dx = (√π)/2
So far this is what I've done:
u = x1/2
du = 1/2 x-1/2
2 ∫ e-u2 u2 du
Now, I'm not really sure what to do? Or if what I've done so far is leading me down the right path
Answers and Replies
andrewkirk
Insights Author
1,464
Try writing it as ##2\int_0^\infty (e^{-u^2}u)\cdot u\,du## and doing integration by parts. If you can get to where the only remaining integral to do is like ##\int_0^\infty e^{-u^2}\,du## you can use the fact that that integrand is a constant multiplied by the pdf of a standard normal distribution, for which the integral from 0 to ##\infty## is known.
Okay, so I did (I'm don't remember how to do this very well so bear with me):
w = u dw = du
dv = e-u2 u du v = -1/2 e-u2
(-u/2) e-u2 - ∫ (-1/2) e-u2 du
-(u/2) e-u2 + (1/2)∫ e-u2 du
For the left side of the equation, would I plug u back in? If so then the limit as x approaches infinity would make that part 0. For the right side, I'm unsure as to whether I just replace the integral with √π /2. If this is all true, then 2( 0 + (1/2) (√π/2)) and would the final answer be √π/2 ?
andrewkirk
Insights Author
1,464
Why have your integration limits disappeared?
The integration by parts rule for definite integrals is:
$$\int_a^b f'(t)g(t)\,dt=\left[f(t)g(t)\right]_a^b-\int_a^b f(t)g'(t)\,dt$$
Okay, so:
2[[(-u/2) e-u2]0 - ∫0 (-1/2) e-u2 du]
2[[(-u/2) e-u2]0 + (1/2)∫0 e-u2 du]
2[(0) + (1/2) (√π/2)] = √π/2
PeroK
Insights Author
2020 Award
17,113
8,932
Okay, so:
Is that ##\frac{\sqrt{\pi}}{2}## or ##\sqrt{\frac{\pi}{2}}##?
The first one, (√π)/2
PeroK
Insights Author
2020 Award
17,113
8,932
Related Threads on Integral sqrt(x)*e^-x
  • Last Post
  • Last Post
  • Last Post
37K
  • Last Post
  • Last Post
  • Last Post
38K
  • Last Post
18K
  • Last Post
15K
  • Last Post
