Integral (x*e^(-3x)). How the !
  • Thread starter TKay
Hello, Forum!
I just registered after seeing you actually help people understand their problems. That's great.
We have (or should have) learned about linearity, substitution and partial integration. However, I don't know when to use which! Could someone also give me a bit of an expanation on this? :(
I have to solve an integral:
x*e^(-3x) dx
My train of thought: I have almost got 2 'basis integrals': x dx and e^x dx. I probably need to substitute to get them to the basic form. But how!
As you see I'm pretty clueless, but what I came up with was:
u = -3x --> u'= -3
v' = x --> v = (x²)/2
However, this leads nowhere. I don't know what to do!
According to derive, the solution is supposed to be:
Code:
     1           -3x  ⎛    x            1       ⎞
⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯ - e           ⎜⎯⎯⎯⎯⎯⎯⎯⎯⎯ + ⎯⎯⎯⎯⎯⎯ ⎟
          2            ⎜ 3·LN(e)              2⎟
 9·LN(e)             ⎝               9·LN(e) ⎠
I sincerely hope someone will be able to show me the light!
Thanks in advance.
PS: Our teacher is really bad at teaching!
Answers and Replies
Kurdt
Staff Emeritus
Try u = x and v' = e^(-3x)
In integration by parts what you're looking to do is reduce any x factors to a constant and thus you set those equal to u. This reduces the right hand side integral to a single function which should be easy to deal with.
If the x factors are higher powers then apply the integration by parts method until the x reduces to a constant or you can come up with a reduction formula.
The substitution method is a little intuitive because you're looking for something that is a derivative of something else in the function. Just keep practising some substitution questions and you will soon start to spot them fairly easily.
For example:
[tex] \int xe^{x^2} dx [/tex]
You can spot that x is almost the derivative of x2. So we use the following substitution:
[tex] u=x^2 [/tex] therefore [tex]\frac{du}{dx}=2x \Rightarrow xdx=\frac{1}{2}du [/tex]
[tex] \frac{1}{2} \int e^u du = \frac{1}{2} e^{x^2} + c [/tex]
The LIATE rule helps you identify which one to use as u.
Order of priority is:
Logarithms, Inverse Trigonometric, Algebraic, Trigonometric, Exponential
Related Threads on Integral (x*e^(-3x)). How the !
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
25K
