Is There a Definition to Calculate Undefined Integrals?
In summary, the person is asking if there is a definition for an undefined integral or if one can use only formules based on assumption that they know what the derivative is. The person also asks if there is any way to calculate an unknown integral.
player1_1_1
114
I need to know if its possible to count undefined and defined integral from definition. When I have derivative of function, ex. [tex]x^3[/tex], I can count this from this: [tex]\left(x^n\right)^{\prime}=nx^{n-1}[/tex], but can also use definition
[tex]\lim_{h\to0}\frac{\left(x+h\right)^3-x^3}{h}[/tex] and its the same. But when I have integral, ex. [tex]\int x^3\mbox{d}x[/tex], I don't have any definition to count this, I must use [tex]\int x^n\mbox{d}x=\frac{x^{n+1}}{n+1}[/tex]. What can I do, if I didnt know this formule? is there any definition to count undefined integral, or I can use only formules based on assumption that we know what function has this derivative?
Trying to do something with derivative definition, but it didnt help me. Thanks for answer;]
By "count", do you mean something like "evaluate"? In that case, the formula for the derivative you listed can be gotten by direct calculation by using the definition of the derivative. A function is differentiable at a if
[tex]\lim_{h\rightarrow 0}\frac{f(a+h)-f(a)}{h}[/tex]
exists. If you compare this to the limit you wrote down for the derivative of x^3, you'll notice your limit is off in the f(a+h) term. Using this definition is often tedious, and thus the generalization (x^n)' = nx^(n-1) is useful.
With integration, it's sort of the same idea. The integration formula you have is NOT the definition of the integral. The formula is a consequence of the fundamental theorem of calculus, which guarantees that a continuous function such as x^3 has an antiderivative. The typical definition for an integral encountered in an elementary calculus course involves Riemann sums. The basic idea is to approximate the area under a curve via rectangles. You could obtain the formula for that type of integral using this method, but it is not a pleasant exercise. If you want to learn more, visit
http://en.wikipedia.org/wiki/Riemann_sum
http://en.wikipedia.org/wiki/Darboux_sum
(these two definitions are equivalent, but I find the later easier to use if you understand sups and infs)
I don't understand what you mean by 'count' in this context, I guess you mean 'compute' or 'calculate'.
The limit approach for calculating a derivative is only practical for 'easy' functions. For an integral, you could pick some partition of your interval [a,b] and actually compute the upper and lower sums, this may lead you to the answer. This also is not very practical.
Or you could use some kind of numerical integration. I'm not sure what you're looking for though.
I think you meant [tex]
\lim_{h\to0}\frac{(x+h)^3-x^3}{h}
[/tex]
Anyway, suppose you know that (I'll leave out the integration constants)
[tex]\int 1 dx = x[/tex]
Then by using partial integration (and knowing how to calculate derivatives) you can get:
[tex]f' = 1; g = x^n;
\int f'g = fg - \int fg' \Rightarrow \int x^n = x^{n+1} - n \int x^n \Leftrightarrow \int x^n = \frac{x^{n+1}}{n+1}[/tex]
You could also do a substitution instead. The point is that you can calculate unknown integrals by transforming them into known integrals. I'm not sure you can do it through a definition though since, if I recall correctly, an indefinite integral is defined as an anti-derivative so you have to know some derivative in the end. I could be wrong of course, I'm not a mathematician. You could try using the definition of the integral as a limit of a Riemann sum or something but I don't know whether it would work very well.
well, thanks for answers, I am going think about this:)
In general "inverse" problems are much harder than "direct" problems. For example, if you are given [itex]f(x)= 4x^5- 3x^3+ 2x^2+ x+ 5[/itex] and are asked to find f(1), that is a "direct" problem- you are given a formula so you can just use the formula to calculate. [itex]4(1)^5- 3(1)^3+ 2(1)^2+ (1)+ 5= 9.
But the "inverse" problem is "find x such that f(x)= 9" and that involves solving a fourh degree equation. Because we know that f(1)= 9, we can say that x= 1 is a solution but we don't know if there are other solutions or what they are.
The same is true of derivatives- we are given a formula and can, theoretically, differentiate any (differentiable) function using that formula. But "anti-derivatives" are defined only as the "inverse" of differentiation. That is, the anti-derivative of the function f is the function F such that F'= f. Since we know that if [itex]F(x)= x^3[/math] then [itex]F'(x)= 3x^2[/itex] we know immediately that an anti derivative of [itex]3x^2[/itex] is [itex]x^3[/itex]. But we need more theory to know that there are other anti-derivatives of the same function and, in fact, need Rolle's theorem to know that they all differ by a constant.
1. What is the definition of an integral?
The definition of an integral is the process of finding the area under a curve, also known as the accumulation of a function, by dividing the area into smaller and smaller rectangles and taking the limit as the number of rectangles approaches infinity.
2. How is an integral represented mathematically?
An integral is represented mathematically as the symbol ∫ followed by the function being integrated and the limits of integration. For example, ∫f(x) dx represents the integral of the function f(x) with respect to x.
3. What is the relationship between an integral and a derivative?
The relationship between an integral and a derivative is that they are inverse operations. The derivative of a function gives the rate of change of the function, while the integral gives the total change or accumulation of the function.
4. What are the two types of integrals?
The two types of integrals are definite and indefinite integrals. A definite integral has specific limits of integration and gives a numerical value, while an indefinite integral has no limits of integration and represents a family of functions that differ by a constant.
5. What is the fundamental theorem of calculus?
The fundamental theorem of calculus states that the definite integral of a function can be evaluated by finding the antiderivative (indefinite integral) of the function and evaluating it at the upper and lower limits of integration. It also states that the derivative of the definite integral of a function is equal to the original function.
