Integrate [1/(x^4 + 4)] dx
In summary, the conversation involved the integration of the function \int \frac{1}{x^4+4}\,dx using various techniques such as u-substitution, partial fractions, and completing the square. After several attempts and corrections, the final answer was determined to be \frac{1}{8}arctan(x+1) + \frac{1}{8}arctan(x-1) + \frac{1}{16}ln(x^2+2x+2) - \frac{1}{16}ln(x^2-2x+2) + C, which was verified by differentiating.
Screwdriver
129
Well gentlemen, another year, another integral eh? Anyways,
[tex]\int \frac{1}{x^4+4}\,dx[/tex]
I really want to do this without looking at Wolfram/Google.
U-substitutions, parts, partial fractions
Basically I tried to factor the denominator and then subtract something to make up the difference:
[tex]\int \frac{1}{x^4+4}\,dx = \int \frac{1}{(x^2 + 2)^2 - 4x^2}\,dx[/tex]
Then I also noticed that:
[tex]\int \frac{1}{(x^2 + 2)^2 - 4x^2}\,dx = \int \frac{1}{(x^2 + 2)^2 - (2x)^2}\,dx[/tex]
Now here's the iffy part; I know that
[tex]\frac{1}{(x^2 + 2)^2 - (2x)^2} \neq \frac{1}{(x^2 - 2x + 2)^2}[/tex]
But I feel like If I can somehow combine those two things I can maybe decompose this into partial fractions. Yay or nay?
a^2 - b^2 = (a+b)(a-b)
Totally gotcha. How embarrassing...
[Edited for an algebraic error]
[tex]\int \frac{1}{(x^2 + 2)^2 - (2x)^2}\,dx = \int \frac{1}{(x^2 + 2x + 2)(x^2 - 2x + 2)}\,dx[/tex]
[tex]\frac{1}{(x^2 + 2x + 2)(x^2 - 2x + 2)}= \frac{Ax+B}{x^2 + 2x + 2}+\frac{Cx+D}{x^2 - 2x + 2}[/tex]
[tex]1=(Ax + B)(x^2 - 2x + 2) + (Cx + D)(x^2 + 2x + 2)[/tex]
[tex]1=A(x^3 - 2x^2 + 2x)+B(x^2 - 2x + 2)+C(x^3 + 2x^2 + 2x)+D(x^2 + 2x + 2)[/tex]
[tex]1=(A + C)x ^3 + (-2A + B + 2C + D)x^2 + (2A -2B +2C + 2D)x + (2B + 2D)[/tex]
[tex]
\end{matrix}
\begin{matrix}
1& 0& 1& 0& |0\\
-2& 1& 2& 1& |0\\
2& -2& 2& 2& |0\\
0& 2& 0& 2& |1
\end{matrix}
[/tex]
Solving yielded A=1/8, B=1/4, C=-1/8 and D =1/4.
[tex]\int\frac{Ax+B}{x^2 + 2x + 2}+\frac{Cx+D}{x^2 - 2x + 2}\,dx = \frac{1}{8}\int\frac{x+2}{x^2 + 2x + 2}\,dx-\frac{1}{8}\int\frac{x-2}{x^2 - 2x + 2}\,dx[/tex]
[tex]\frac{1}{8}\int\frac{x+2}{x^2 + 2x + 2}\,dx =\frac{1}{8}\int\frac{x}{x^2 + 2x + 2}\,dx + \frac{1}{4}\int\frac{1}{x^2 + 2x + 2}\,dx[/tex]
and
[tex]-\frac{1}{8}\int\frac{x-2}{x^2 - 2x + 2}\,dx =-\frac{1}{8}\int\frac{x}{x^2 - 2x + 2}\,dx +\frac{1}{4}\int\frac{1}{x^2 - 2x + 2}\,dx[/tex]
Another roadblock. How can I integrate those 4 integrals? Some of them look like lns and arctans...
Looks like a good place to complete the square for at least one of them.
You should check your calculations of A and C. I got A=1/8 and C=-1/8 in Mathematica.
Just out of curiousity, did you run into this integral while trying to integrate [tex] tan^{-1}(x)[/tex] ? I remember running into some messy algebra for that guy and your question looks similar.
Do something like
[tex]\int\frac{x}{x^2 - 2x + 2}\,dx = \frac{1}{2}\int\frac{2x-2}{x^2 - 2x + 2}\,dx + \int\frac{1}{x^2 - 2x + 2}\,dx[/tex]
The first integral on the RHS you can do with a simple substitution.
You're right. There's an extra D in the matrix; I'm going to edit that post to fix it.
Just out of curiousity, did you run into this integral while trying to integrate[tex]
No, I ran into it by itself :tongue2:
Using the suggestion put forth by Apphysicist:
[tex]\frac{1}{4}\int\frac{1}{x^2 + 2x + 2}\,dx = \frac{1}{4}\int\frac{1}{(x+1)^2+1}\,dx[/tex]
[tex]u = x + 1[/tex]
[tex]du = dx[/tex]
[tex]\frac{1}{4}\int\frac{1}{(u)^2+1}\,du=\frac{1}{4}arctan(x +1)[/tex]
And for the other one:
[tex]\frac{1}{4}\int\frac{1}{x^2 - 2x + 2}\,dx = \frac{1}{4}\int\frac{1}{(x-1)^2+1}\,dx[/tex]
[tex]u = x - 1[/tex]
[tex]du = dx[/tex]
[tex]\frac{1}{4}\int\frac{1}{(u)^2+1}\,du=\frac{1}{4}arctan(x -1)[/tex]
Using the suggestion put forth by vela, modified slightly:
[tex]\frac{1}{8}\int\frac{x}{x^2 + 2x + 2}\,dx =\frac{1}{16}\int\frac{2x+2}{x^2 + 2x + 2}\,dx - \frac{1}{8}\int\frac{1}{x^2 + 2x + 2}\,dx[/tex]
I've already evaluated the right integral previously, it will be
[tex]-\frac{1}{8}arctan(x +1)[/tex]
So for the left one:
[tex]\frac{1}{16}\int\frac{2x+2}{x^2 + 2x + 2}\,dx[/tex]
[tex]u=x^2+2x+2[/tex]
[tex]du=(2x+2)dx[/tex]
[tex]\frac{1}{16}\int\frac{1}{u}\,dx[/tex]
[tex]\frac{1}{16}ln(x^2+2x+2)[/tex]
Last two:
[tex]-\frac{1}{8}\int\frac{x}{x^2 - 2x + 2}\,dx =-\frac{1}{16}\int\frac{2x-2}{x^2 - 2x + 2}\,dx -\frac{1}{8}\int\frac{1}{x^2 - 2x + 2}\,dx\\[/tex]
I know that they're going to be
[tex]-\frac{1}{8}arctan(x -1)[/tex]
and
[tex]-\frac{1}{16}ln(x^2-2x+2)[/tex]
So FINALLY, the four arctans will combine leaving:
[tex]\int\frac{1}{x^4+4}\,dx = \frac{1}{8}arctan(x +1) +\frac{1}{8}arctan(x-1)+\frac{1}{16}ln(x^2+2x+2)-\frac{1}{16}ln(x^2-2x+2)+C[/tex]
Man triumphs over machine.
Now differentiate it and simplify to check your answer. :wink:
From Screwdriver's 2nd post.
Screwdriver said:
[tex]\int\frac{Ax+B}{x^2 + 2x + 2}+\frac{Cx+D}{x^2 - 2x + 2}\,dx = \frac{1}{8}\int\frac{x+2}{x^2 + 2x + 2}\,dx-\frac{1}{8}\int\frac{x+2}{x^2 - 2x + 2}\,dx[/tex]
[tex]\frac{1}{8}\int\frac{x+2}{x^2 + 2x + 2}\,dx =\frac{1}{8}\int\frac{x}{x^2 + 2x + 2}\,dx + 2\int\frac{1}{x^2 + 2x + 2}\,dx[/tex]
and
[tex]-\frac{1}{8}\int\frac{x+2}{x^2 - 2x + 2}\,dx =-\frac{1}{8}\int\frac{x}{x^2 - 2x + 2}\,dx +2\int\frac{1}{x^2 - 2x + 2}\,dx[/tex]
The next to last line should be:
[tex]\frac{1}{8}\int\frac{x+2}{x^2 + 2x + 2}\,dx =\frac{1}{8}\left(\int\frac{x}{x^2 + 2x + 2}\,dx + 2\int\frac{1}{x^2 + 2x + 2}\,dx\right)[/tex]
The last line should be:
[tex]-\frac{1}{8}\int\frac{x+2}{x^2 - 2x + 2}\,dx =-\frac{1}{8}\left(\int\frac{x}{x^2 - 2x + 2}\,dx +2\int\frac{1}{x^2 - 2x + 2}\,dx\right)[/tex]
I don't know if you carried this mistake through to the end.
Turns out that not only did I do that, I also made about 10 other mistakes that took forever to find. I fixed and edited every post though - thanks for catching that mistake; my final answer was incorrect before :rolleyes:
Now I'm positive that it's right :smile:
[tex]d/dx[\frac{1}{8}arctan(x+1) +\frac{1}{8}arctan(x-1)+\frac{1}{16}ln(x^2+2x+2)-\frac{1}{16}ln(x^2-2x+2)+C][/tex]
[tex]=\frac{1}{8(x^2+2x+2)}+\frac{1}{8(x^2-2x+2)}+\frac{x+1}{8(x^2+2x+2)}-\frac{x-1}{8(x^2-2x+2)}[/tex]
[tex]=\frac{x+2}{8(x^2+2x+2)}-\frac{x-2}{8(x^2-2x+2)}[/tex]
[tex]=\frac{1}{(x^2+2x+2)(x^2-2x+2)}[/tex]
[tex]=\frac{1}{x^4+4}[/tex]
Man triumphs over...self?
What is the process for integrating 1/(x^4 + 4)?
The process for integrating 1/(x^4 + 4) involves using substitution and partial fraction decomposition. The substitution involves setting u = x^2, which transforms the integral into 1/(u^2 + 4). Then, the partial fraction decomposition can be used to break down the integrand into simpler fractions that can be easily integrated.
What are the limits of integration for this integral?
The limits of integration for integrating 1/(x^4 + 4) are typically from negative infinity to positive infinity, as the integrand is defined for all real numbers.
Can this integral be solved using any other methods?
Yes, this integral can also be solved using trigonometric substitution or by using a table of integrals. However, the substitution and partial fraction decomposition method is the most common approach.
What is the final result of integrating 1/(x^4 + 4)?
The final result of integrating 1/(x^4 + 4) is (1/8)arctan(x^2/2) + C, where C is the constant of integration.
Why is it important to understand how to integrate 1/(x^4 + 4)?
Understanding how to integrate 1/(x^4 + 4) is important for solving a variety of other integrals that involve rational functions. It also helps develop a deeper understanding of substitution and partial fraction decomposition techniques, which are widely used in calculus and other areas of mathematics.
