Integrating sqrt(1+4x^2) from x = 0 to x = 1: A Step-by-Step Solution
  • Thread starter applestrudle
  • Tags
    Integrate
I recommend a daily dose of humility and self-deprecation. And never get too confident about your own understanding. Always be a bit skeptical and keep checking yourself.
applestrudle
64
Integrate sqrt(1+4x^2)
limits x = 0 to x = 1
let 2x = sinhu
I = 0.5 ∫ (coshu)^2du
limits u = 0 u = sinh^-1(2)
0.5 ∫ (e^2u +e^-2u +2)/4 du
0.5 [(e^2u)/8 -(e^-2u)/8 +2u]
I = 2.56 which is wrong :(
why is it wrong?
please help!
let 2x = sinhu
why is it wrong?
please help!
Well, for one thing 0.5 ∫ (e^2u +e^-2u +2)/4 du becomes
0.5 [(e^2u)/8 -(e^-2u)/8 +u/2]. Did you forget to divide the last term by 4?
Likes 1 person
You started out well. I think you made an arithmetic mistake when you multiplied your expression through by .5 -- you got ##e^{2u}/8 + e^{-2u}/8 +2u##. Where did you get 2u. Shouldn't it be u/4?
what a silly mistake, i feel embarrassed :S
I recently wrote that 25 is divisible by 3. And just a few months ago based a proof on the non-fact that 10 is prime. Talk about embarrassed. Losing a factor of 4 is much more understandable.
We cannot escape these boneheaded errors.
1. What is the basic concept of integration?
The basic concept of integration is finding the area under a curve. It is the inverse process of differentiation and involves finding the antiderivative of a function.
2. How do you integrate a square root function?
To integrate a square root function, you can use the substitution method or integration by parts. In this case, we can use the substitution method by letting u = 1 + 4x^2, which simplifies the integral to ∫√u du.
3. What is the general formula for integrating √(1+4x^2)?
The general formula for integrating √(1+4x^2) is ∫√(1+4x^2) dx = (1/4)∫√u du = (1/8)(u√u + ln|u|) + C, where u = 1 + 4x^2.
4. Can the integral of √(1+4x^2) be evaluated using basic integration rules?
No, the integral of √(1+4x^2) cannot be evaluated using basic integration rules. It requires the use of advanced integration techniques such as substitution or integration by parts.
5. What is the significance of integrating √(1+4x^2) in scientific research?
The integration of √(1+4x^2) is commonly used in physics and engineering to calculate the work done by a varying force. It is also used in calculating the arc length of a curve in mathematics and has applications in other fields such as economics and biology.
