Integrating 2x/(3x+1)
  • Thread starter lionely
lionely
576
Verify, by division, that 2x/(3x+1) = 2/3 - 2/3(3x+1)
Hence, evaluate ∫2x/(3x+1) dx
I don't understand what to, does the question mean to do long division?
Help is much appreciated!
Answers and Replies
CompuChip
4,306
49
It's easier to start from the right hand side: take 2/3 - 2/3(3x + 1) and combine the fractions into one. After simplification, you should get 2x/(3x + 1).
vanhees71
Insights Author
2021 Award
20,824
11,675
[tex]\frac{2x}{3x+1}=\frac{2}{3} \cdot \frac{3x}{3x+1}=\frac{2}{3} \cdot \frac{3x+1-1}{3x+1}=\ldots[/tex]
lionely
576
Oh thanks, vanhees. But is that still division?
Ray Vickson
Dearly Missed
10,706
1,722
"Division" means re-writing the expression so that in the remainder the numerator has a smaller degree than the denominator. So, if we have f(x) = p(x)/q(x), it is already in "divided" form if deg(p) < deg(q); otherwise (if deg(p) ≥ deg(q)), manipulate the expression to get f(x) = m(x) + r(x)/q(x), with deg(r) < deg(q). (Of course, I mean that p,q,m,r are all polynomials in x.) In your example, deg(p) = 1 = deg(q), so you need to re-write the expression until the remainder has numerator of degree 0 (that is, has the form c/(3x+1) for constant c).
lionely
576
Thank you Ray.
arildno
Dearly Missed
10,025
135
Or, by polynomial long division
2x:(3x+1)->2/3
2x+2/3
0-2/3
Implies:
2x/(3x+1)=2/3-2/3*(1/(3x+1))
vanhees71
Insights Author
2021 Award
20,824
11,675
[tex]\frac{2x}{3x+1}=\frac{2}{3} \cdot \frac{3x}{3x+1}=\frac{2}{3} \cdot \frac{3x+1-1}{3x+1}=\frac{2}{3} \left (1-\frac{1}{3x+1} \right).[/tex]
Written in this form, the integral is very easy. I don't know, how you call these simple manipulations.
Ray Vickson
Dearly Missed
10,706
1,722
It is impossible to tell which message you are responding to, since you did not use the "Quote" button. Anyway, these manipulations are called simple because they are simple. (However, as far as I can tell, nobody called them simple before you did, so I don't understand your statement!)
vanhees71
Insights Author
2021 Award
20,824
11,675
Come on, it is really simple to integrate now!
CompuChip
4,306
49
Euh, guys... am I the only one who is getting confused here, or are you all replying to the wrong messages. The OT seems to have gotten the hint back in post #6; none of the other posters is the topic starter and knows perfectly well how to solve the exercise, so what is the discussion about?
arildno
Dearly Missed
10,025
135
I merely offered an alternative solution procedure! :smile:
D H
Staff Emeritus
Insights Author
15,415
687
That's typical in homework problems. We have a tendency to drag the discussion off topic. The OP hasn't come back since post #6, so presumably the problem has been solved.
That said, I suspect arildno's post #7 is exactly what the instructor intended with the phrase "verify, by division."
Suggested for: Integrating 2x/(3x+1)
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
