Integrating (4x+1)^1/2
Tags:
  1. Aug 29, 2015 #1
    Integrate (4x+1)^1/2
    2. Relevant equations
    Integration (ax+b)^n dx= (ax+b)^(n+1)/ a(n+1)
    3. The attempt at a solution
    (4x+1)^(3/2)/ 4(3/2)
    = (4x+1)^(3/2)/6
    but the actual answer is
    3(4x+1)^(3/2)/8
  3. Aug 29, 2015 #2
    SammyS
    Staff Emeritus
    Take the derivative of your result and the correct result. Compare to help you see where you went awry .
  4. Aug 29, 2015 #3
    Ray Vickson
    No, the actual answer is what YOU obtained. Try differentiating your answer, to check if you get back your initial ##(4x+1)^{1/2}##.
  5. Aug 29, 2015 #4
    ehild
    Your result is correct. (but do not forget adding a C constant :smile:)
  6. Aug 30, 2015 #5
    It does. Thank you!
  7. Aug 30, 2015 #6
    I keep forgetting to add the constant! Thanks!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Integrating (4x+1)^1/2
  1. Integrate sqrt(1+4x^2) (Replies: 4)
  2. Integral (9-4x^2)^1/2 (Replies: 11)
Loading...
