Integrating Complex Equations: A Step-by-Step Guide
In summary: Thanks for clearing that up for me. :)In summary, the student is struggling with the homework and needs help with solving the equations.
[tex]\int{\frac{t}{(1+t^{2})^3}dt}[/tex]
2.)
[tex]\int{xe^{-2x}dx.}[/tex]
3.)
[tex]\int{\frac{x.dx}{2+x^{2}}}[/tex]
This one is inegrating between 2 and 0, but I didn't know how to format that in.
4.)
[tex]\int{\frac{cos t}{1 + sin t}dt.}[/tex]
Q 1.)
I'm substituting [tex]u = 1 + t^{2}[/tex]
Q 2.)
[tex] uv - \int{vdu}[/tex]
where u = x
and
dv = [tex]e^{-2x}[/tex]
Q 3 & 4.)
I'm afraid I'm well and truly stuck with these, I think for number 3 I want to use function over a function rule possibly?
Promise not to laugh ok :redface:
1.)
Rearranging to [tex]\int{t.u^{-3}}[/tex]
using [tex] uv - \int{vdu}[/tex]
[tex] t.\frac{-1}{2}u^{-2} - \int{\frac{-1}{2}u^{-2}.t^{2}[/tex]
which is:
[tex] t.\frac{-1}{2}u^{-2} - (u^{-2}.\frac{1}{3}t^{3})[/tex]
Am I anywhere close?
As for the others I'm afraid I've not much idea.
2.) could be
using [tex] uv - \int{vdu}[/tex] again:
[tex]x.-2e^{-2x} - \int{-2e^{-2x}}[/tex]
which goes to
[tex]x.-2e^{-2x} - 4e^{-2x}[/tex]
But once again, I could be wildly wrong.
It's not so much that I think I'm going wrong, it's more that I've no idea how to approach the questions. Any nudges in the right direction would be fantastic
Thank you.
For 1) you're not doing your substitution correctly. While the substitution [itex]u=1+t^2[/itex] is a good one, you ignore that this would also mean [itex]du=d(1+t^2)=2tdt \Rightarrow tdt=\frac{1}{2} du[/itex]. Try 1) again now.
Regarding 2). You're pretty close, however instead of integrating the exponential you're differentiating it every time, fix that and you will have solved 2).
3) You will have to do a substitution, what do you think is a good one?
4)Again a substitution, any ideas?
Thanks Cyosis. I tried to find a way to give you reputation points but it doesn't seem to exist on this board. Just so you know I really appreciate your help :)
For 3.) and 4.) I would've thought substituting the denominator of each fraction. So:
[tex] u = (2 + x^{2})[/tex] and [tex] u = (1 + sin t)[/tex] respectively.
I'll have a look at 1.) and 2.) now following your help.
p.s. for number 3.) Would it be incorrect to follow the function over a function rule? It's just that I see that the differential of [tex]2 + x^{2}[/tex] would equal [tex]2x[/tex] and seem to remember a way to integrations in the form [tex]\frac{f(x)}{(f'(x)}[/tex] however I could be wrong.
Yep those are the correct substitutions for 3) and 4).
I am not sure what kind of rule you're talking about, but if you've a function where the numerator is the derivative of the denominator you can integrate the expression. This is however just a special case of the 'substitution rule' for integrals.
Example: using the substitution u=f(x), du=f'(x)dx
[tex]
\int \frac{f'(x)}{f(x)}dx=\int \frac{du}{u}=\log u+C=\log f(x)+C
[/tex]
So for number 3.)
[tex]\int{\frac{x.dx}{2 + x^{2}}}[/tex]
I could give the answer [tex] 2log(2 + x^{2}) + c[/tex]?
As:
[tex]\int{\frac{x.dx}{2 + x^{2}}} = 2\int{\frac{f'(x)}{f(x)}}}[/tex]
Well not entirely right since the derivative of the denominator needs to be equal to the numerator. In this case [itex]2x \neq x[/itex]. You can however write x as (1/2)2x. Thus you get [itex]\frac{1}{2}\int \frac{2x}{2+x^2}dx=\frac{1}{2} \log{(2+x^2)}+C[/itex].
However I really suggest you do not just use this as a rule, but instead do the substitution yourself so you can practice.
Hint: Always differentiate your expression after integration to see if it's correct.
Ahhh ok then. I'll work through these and update tomorrow. Thanks for all of your help again.
Just a thought, I'll work through number 4 with substitution as well. But does that not follow the same rule?
[tex]\int{\frac{cos t}{1 + sin t}dt}[/tex]
Differentiatial of the denominator is [tex]-cos t[/tex]
resulting in:
[tex]-1\int{\frac{cos t}{1 + sin t}dt = -log(1 + sin t) + C?[/tex]
I think I may have gone wrong with the -1 there, not sure.
resulting in:
That would be fine if the derivative of sin(t) were -cos(t), but it's not. It's +cos(t).
Lol. I'm in integration mode, my bad.
Doesn't that just make it even easier?
Because that means that:
[tex]\int{\frac{cost}{1 + sint}dt} = \int{\frac{f'(x)}{f(x)}} [/tex]
therefore:
[tex]\int{\frac{cost}{1 + sint}} = log(1 + sint) + C?[/tex]
Sure. You can always check yourself by differentiating the result.
1. What is the purpose of "Integrating Complex Equations: A Step-by-Step Guide"?
The purpose of this guide is to provide a clear and comprehensive explanation of how to integrate complex equations. It is designed to help scientists and students understand and apply the process of integration, which is essential in many fields of science and mathematics.
2. What is the difference between simple and complex equations?
Simple equations typically involve only one variable and can be solved using basic operations such as addition, subtraction, multiplication, and division. Complex equations, on the other hand, involve multiple variables and often require more advanced mathematical techniques such as integration to solve.
3. Why is integration important in scientific research?
Integration is a powerful tool for analyzing and understanding complex systems in science. It allows scientists to model and predict the behavior of physical, chemical, and biological processes by finding the area under a curve and determining the total change in a system over a given interval.
4. What are the basic steps for integrating a complex equation?
The basic steps for integrating a complex equation include: identifying the variables, determining the limits of integration, simplifying the equation, applying integration rules, and solving for the constant of integration. It is important to follow these steps in order and carefully check the solution for accuracy.
5. Is there a specific method for integrating all types of complex equations?
No, there is not a single method for integrating all types of complex equations. The approach used will depend on the specific equation and its variables. It is important to be familiar with different integration techniques, such as substitution, integration by parts, and trigonometric substitution, to effectively solve a variety of complex equations.
Suggested for: Integrating Complex Equations: A Step-by-Step Guide
