Homework Help: Integrating factor
  1. Feb 16, 2010 #1
    Integrating factor!!
    As promised I'm back with integrating factor differential equation.
    (x^2 + 1)dy/dx -2xy = 2x(x^2+1) y(0)=1
    First put into standard from by dividing thru by (x^2 +1 )
    dy/dx -2xy/(x^2 + 1) = 2x
    Integrating factor is given by exp( integral of -2x(x^2 + 1))
    After some working out I get the IF to be 1/(x^2 + 1)
    Now the solution is given by
    y(x)=1/IF(integral of 2x(x^2 + 1)
    Hopefully I'm on the right track so far...
    After doing the integration by parts and some tidying up I have
    y(x)= (x^2 + 1){(2(x^2 + 1)x^3)/3 - 4x^5/15} + C
    After plugging in the values I have 1=C
    What do you think??
  3. Feb 16, 2010 #2
    Re: Integrating factor!!
    On checking my work I think I've mad a mistake
    the equation should be
    y(x) = 1/IF{integral of 2x/(x^2 + 1)}
    Which makes it different...
    My final revised answer is
    y(x) = (x^2 + 1)(ln{x^2 + 1}) + C
    After plugging in values y(0)=1
    I have y(x)=(x^2 + 1)(ln{x^2 + 1}) + 1
    Cheers!!!
  4. Feb 16, 2010 #3
    vela
    Staff Emeritus
    Education Advisor
    That's almost right. Did you try plugging it back into the original equation to see if it worked?
  5. Feb 16, 2010 #4
    I haven't and I'm not really sure how to do it or what you mean! Forgive my ignorance but can you show me....
    James
  6. Feb 16, 2010 #5
    Mark44
    Staff: Mentor
    You have your differential equation back in your original post in this thread. In post 2 you have a solution, y(x)=(x^2 + 1)(ln{x^2 + 1}) + 1.
    Does this function satisfy the initial condition? I.e., is y(0) = 1?
    Does this function satisfy the differential equation? I.e., if you replace y and dy/dx in the differential equation with the function above and its derivative, do you get a true statement in this equation: (x^2 + 1)dy/dx -2xy = 2x(x^2+1)?
    You should always check your solutions to differential equations.
  7. Feb 16, 2010 #6
    Yes my solution satisfies condition y(0)=1
    So I now need to differntiate my solution and substitute back into the equation? I'm not sure I get what you mean sorry? Bear in mind I'm trying to learn this...! lol
    James
  8. Feb 16, 2010 #7
    Mark44
    Staff: Mentor
    Yes, that's what I mean. Take the derivative of your solution. Multiply it (the derivative) by (x^2 + 1). Subtract 2x times your solution. If you get 2x(x^2 + 1), your solution satisifies the DE.
  9. Feb 16, 2010 #8
    I don't! After doing what you said I arrive at (x^2 + 1) - 1
    Which is x^2.
    So my solution is wrong?
  10. Feb 16, 2010 #9
    Mark44
    Staff: Mentor
    Yes, it's wrong. That's what vela was suggesting that you do back in post #3. Now that you know you have a mistake, go back and take another look at your work and see if you can spot an error.
  11. Feb 16, 2010 #10
    Thanks for your help Mark, I've been over my solution several times but always get the same - and its worng? I just can't see where Ive gone wrong...
    Is it my integrating factor?
    James
  12. Feb 16, 2010 #11
    vela
    Staff Emeritus
    Education Advisor
    Hint: Your mistake has to do with when you introduced the constant of integration.
  13. Feb 16, 2010 #12
    Hmmm I'm not sure, but at a guess should it be ln(C) not just C ??
  14. Feb 16, 2010 #13
    Hold on! I think I may have it...?
    I should have multiplied at all by 1/IF making my constant thus
    C(x^2 + 1)
    Or am I way off again...
    James
  15. Feb 16, 2010 #14
    vela
    Staff Emeritus
    Education Advisor
    Yup, that's it. You can, of course, check your answer by plugging it back into the original differential equation.
  16. Feb 16, 2010 #15
    Thanks for your help everyone, my revised solution works! I've learned a lot, your gentle pointers eventually made the penny drop.
    At least now I know how to check my solutions!
    Thanks again.
    James
    P.S
    I'll be moving onto 2nd order differential equations next and looking forward to your help again...
