Homework Help: Integrating mod function
  1. Dec 3, 2016 #1
    I need to integrate
    ##\langle |v_x| \rangle = \int^{\infty}_0 |v_x| \sqrt{\frac{m}{2\pi kT}}e^{-mv_x^2/2kT}dv##
    For context this is a Maxwell boltzmann distribution in one dimension, and I've actually been asked to calculate ##\langle v_x \rangle## which is given by ##|v_x|f(v)## where ##f(v) = \sqrt{\frac{m}{2\pi kT}}e^{-mv_x^2/2kT}## is the Maxwell Boltzmann distribution in the x-direction. Not sure if the question is best put in physics or maths.
    2. Relevant equations
    3. The attempt at a solution
    I'm a little confused because since ##v_x## is always positive between infinity and zero (I think?) the integral is actually just ##\langle v_x \rangle##, since the mod can be ignored if it's always positive. That can't be it though, I've already been asked to calculate ##\langle v_x \rangle## in the first part of the same question. So I suppose my treatment of the mod must be wrong.
    Thanks for any help!
  3. Dec 3, 2016 #2
    Ray Vickson
    What was your result for ##\langle v_x \rangle##?
    Do you see why ##\langle v_x \rangle \neq \langle |v_x| \rangle##?
    What slight (but important) error have you made in your expression for ## \langle |v_x| \rangle##?
  4. Dec 3, 2016 #3
    Is the error related to the limits, by any chance? Should probably go to ##-\infty## and that would explain a lot.
  5. Dec 3, 2016 #4
    Ray Vickson
    Try it, to see what you get.
    Anyway, what is your answer to my question about ##\langle v_x \rangle##?
  6. Dec 3, 2016 #5
    It is the limits, velocity can be negative, I'd been working with speed in 3D so only needed to integrate ##\infty## to zero. Didn't read the question carefully so missed that we had moved to velocity distribution. As to ##\langle v_x \rangle##, I have that equal to zero.
  7. Dec 3, 2016 #6
    Ray Vickson
    Right: ##\langle v_x \rangle = 0##, and this follows immediately (with essentially no work) from the fact that ##f(v_x)## is an even function of ##v_x##, so ##v_x f(v_x)## is an odd function. In contrast, ##|v_x| f(v_x)## is an even function of ##v_x##, so its integral over the whole line can be easily related to its integral over the half-line ##\{ v_x \geq 0 \}##.
Have something to add?
Draft saved Draft deleted
Loading...
