Homework Help: Integrating Rational Function
  1. Jan 31, 2013 #1
    integrate the following:
    2. Relevant equations
    ∫(x/(x-1)^3
    3. The attempt at a solution
    i've tried u-substitution, finding an inverse trig function that matched the formula, and still can't figure out how to solve this problem.
    u-subtitution for u=x gives the same problem. u-subsitution for x-1 gives du =1 which does not match the problem.
  3. Jan 31, 2013 #2
    Dick
    u=(x-1) gives du=dx which does match the problem. If you are worried about the x in the numerator, if u=x-1, then x=u+1.
  4. Jan 31, 2013 #3
    Its a fairly easy integral..dont go all complicated when you cant find the answer just stay on the ground bro :tongue2: sometimes few problems can be easily solved if you just view it from a different angle
    this should work. you would get u+1/u^3 du which you split and integrate
  5. Jan 31, 2013 #4
    Ray Vickson
    No, you will not get [tex]u + \frac{1}{u^3},[/tex] which is what you wrote! If you really mean [tex] \frac{u+1}{u^3}, [/tex] use parentheses, like this: (u+1)/u^3.
  6. Jan 31, 2013 #5
    Dick
    Good advice but use more parentheses. You could easily mistake u+1/u^3 for u+(1/u^3) when you meant (u+1)/u^3.
  7. Jan 31, 2013 #6
    lol thanx for pointing it out..my bad :shy:
