Why are the results of this natural log integration seemingly inconsistent?
In summary, the conversation is about integrating (-m-kx)^-1 dx from a to b. The integral form is found to be (-1/k)*[ln(-m-kx)] with the bracketed expression evaluated between a and b. However, there are concerns about negative arguments in the natural log function, which can be resolved by using properties of logs to obtain the equivalent expression (-1/k)*ln((m+ka)/(m+kb)). The book's answer, (-1/k)*ln((m+kb)/(m+ka)), is also discussed, though it may not be reliable due to the book's reputation for typos. The suggestion is made to start the integration as \int_a^b \dfrac
PsychonautQQ
784
Integrate (-m-kx)^-1 dx from a to b.
So using the integral form I get the integral of (-m-kx)^-1 dx is (-1/k)*[ln(-m-kx)] with the bracketed expression being evaluated between a and b.
(-1/k)*[ln(-m-ka) - ln(-m-kb)]
My first problem with this is that if we assume m,k,a,b are all positive then the negative argument of the natural log function will lead the function to not have a proper result, but if we use properties of log's to adjust the expression we arrive at an equivalent expression:
(-1/k)*ln((-m-ka)/(-m-kb))
which is equivalent to
which DOES have a proper answer since the argument of the log function is now positive... what voodoo is going on here!?
Furthermore and most frusturating of all is that the back of my book says the integral should come out to (-1/k)*ln((m+kb)/(m+ka)). However this book is infamous for typo's so the answers can't be trusted. Any mathamagical mavericks out there want to spread some light on my dilemma's?
Why not start the integration as
[tex]
\int_a^b \dfrac{1}{-m-kx} \, dx = \int_a^b \dfrac{-1}{m+kx} \, dx = -\int_a^b \dfrac 1 {m+kx} \, dx
[/tex]
and see how your integral turns out?
Whether the numbers are positive or not is not directly relevant: [tex]\int \frac{du}{u}= ln|u|+ C[/tex].
Of course, you will want to let u= -m- kx.
What is integration?
Integration is a mathematical process that involves finding the area under a curve. It is the inverse operation of differentiation and is used to solve a wide range of problems in mathematics and science.
What is the fundamental theorem of calculus?
The fundamental theorem of calculus states that integration and differentiation are inverse operations, and that the integral of a function is equal to the change in the antiderivative of that function. In other words, it provides a way to find the area under a curve without using geometric formulas.
What is a natural logarithm?
A natural logarithm is a logarithm with a base of the mathematical constant e (approximately equal to 2.718). It is written as ln(x) and represents the exponent that e must be raised to in order to get x. It is commonly used in mathematics and science, especially in situations involving exponential growth or decay.
Why are natural logarithms used in integration?
Natural logarithms are used in integration because they simplify the process of calculating the area under a curve. They allow for the use of rules and formulas that make integration easier and more efficient.
What are some real-world applications of integration and natural logs?
Integration and natural logs have many real-world applications, including calculating the area under a velocity-time graph to determine displacement, finding the rate of change in population growth, and solving differential equations in physics and engineering. They are also used in economics, biology, and other fields to model and analyze various processes.
17K
