Integration by parts HELP
  • Thread starter Tino
Integration by parts HELP !!!!
Ok to be honest with all of you reading this post, i just dont understand how integration by parts work.
Can someone please explain how it works?
I have looked on the internet for help reading through all the notes but i still do not understand.
So please somone explain to me in the easiest way.
Here is an example :
Integrate (2x Sin 3x) dx
:uhh: :uhh: :uhh: :uhh:
arildno
Dearly Missed
9,948
130
1. Do you understand the product rule of differentiation?
Essentially, integration by parts is nothing but the reverse operation of the product rule.
2. Let us construct a function h(x)=u(x)v(x)
Then, the product rule gives us:
[tex]\frac{dh}{dx}=\frac{du}{dx}v(x)+u(x)\frac{dv}{dx}[/tex]
This can of course be rewritten as:
[tex]u(x)\frac{dv}{dx}=\frac{dh}{dx}-\frac{du}{dx}v(x)[/tex]
This is the form of the product rule we use in integration by parts.
3. Integration by parts.
Suppose we may write an integrand in the form of [tex]u(x)\frac{dv}{dx}[/tex]
(in your particular example, we may choose, say [tex]u(x)=2x, \frac{dv}{dx}=\sin(3x)[/tex])
Then, from 2, we have:
[tex]\int{u}(x)\frac{dv}{dx}dx=\int\frac{dh}{dx}dx-\int\frac{du}{dx}v(x)dx[/tex]
Are you following thus far?
hello there
the only time you would use integration by parts is when you have the product of 2 functions one in which you can reduce which is the [tex]u(x)=2x[/tex] through differentiation so that it equals to a constant or you would want to reduce it to something that will get eliminated once multiplied by the integral of [tex]\frac{dv}{dx}[/tex] so that it gets reduced to something that is integrable for example try doing integration by parts for
[tex]\int \log x dx[/tex]
if you can do this example and the one you are having trouble with you would pretty much prepared to use integration by parts when necessary
I see, so one wouldn't want to use integration by parts to integrate sin(x) * e^x, then ;)
176
woops i forgot one more sanario thanxs muzza lucky you mentioned it, a person tryin to do that for the first time would probably end up in circles lol thats pretty complicated to explain unless you actually do it,
788
That integral requires integration by parts twice and then some rearranging, but it can be solved by this method.
788
As for the original integral....
[tex]\int2x\sin{(3x)}dx[/tex]
dv = sin(3x)
u = 2x
[tex]\int udv = uv - \int vdu[/tex]
[tex]\int2x\sin{(3x)}dx = 2x\int sin{(3x)}dx - \int 6\cos{(3x)}dx[/tex]
694
Yes, precisely my point...
Hmmm ??
Ok thanks for all your reply but for the problem i have, so far i understand the rule :
integrate u dv = u v - integrate v du
i have put all the bits into the equation from this problem and it looks something like this, i dont know if its right.
integrate (2x)(Sin 3x dx) = 2x (-1/3 Cos 3x) - integrate (-1/3 Cos 3x)(2 dx)
now here is the problem what do i do after this ??????
Please help
Thanks a bunch !!!!!
cronxeh
Continue until you solve it (meaning you might have to do integration by parts or integration by substitution again and again and again and again until everything is killed off)
In case you succeed make sure to check for correct answer:
[tex]\frac{2}{9} sin(3x) - \frac{2}{3}x cos(3x) + C[/tex]
hmm don't understand lol
Ok i get what u mean by integrating the equation but, how do i do it :
can u show me the steps because i mean there are two integration i have to do but how do i but them together ???
please show the steps and explain if you can !!!!!
176
hello tin0
well all you have to do is evaluate the right hand side and this is done by integrating the second term, you do know how to integrate cos3x coz really thats all you have to get your answer, you have already integrated sin3x so you should be able to do this integration, anyway i hope i have given you more than enough hints to get you answer
:smile:
cronxeh
As you've said it yourself your problem now simplified to
Now go ahead and find [tex]\int{\frac{-2}{3} cos(3x) dx[/tex] using substitution method (try substituting something in cosine to make it a very easy trig function that can be easily integrated, and dont forget to check for any additional things you would need after substituion (like perhaps checking if your new substituted's variable derivative has enough numbers for that original integral)
I tried
So far i got to is :
integrate (2x Sin 3x) dx
u = 2x
dv = Sin 3x dx
du/dx = 2
du = 2 dx
v = -1/3 Cos 3x
= 2x (-1/3 Cos 3x) - integrate -2/3 Cos (3x) dx
But i have never even learnt how to use substitution by trigometry method so is there any other way i can do it ???
if i do integration by substitution with this :
u = -2/3 Cos (3x) or u = -2/3 Cos
du/dx = 2/3 3Sin 3x or du/dx = 2/3 Sin
I dont know what to do this is really confusing lol ?????
176
hello there
well lets use another dummy variable r since we have already used u anyway
let r=3x
dr/dx=3
dx=dr/3 then use the substitution method .
now the most easiest way to do it is to look up a full table of standard integals and look for something that looks like what you are working with, it isnt that complicated
steven
I am still confused !!!
Ok integration by substitution :
r = -2/3 cos 3x why r = 3x ??????????????
lol
can u show me the steps how to do it ????
cronxeh
You can take out the coefficients outside because they are not to be integrated - they are just coefficients without the 'x' so to speak. The simplest trig function for you to do is cos(u). So you have 2/3 integral ( cos(3x) dx). Now what do you think you should do to make it into 2/3 integral (cos(u) du)? You substitute:
u = 3x
du = 3dx
1/3 * -2/3 integrate (cos(u) du)
Since you need 3dx in order to substitute for u you have to multiply 3 by cos(u), but now you must balance it out by multiplying by 1/3 outside. Hence your answer ends up being 2/9 sin(3x) for this integral. Add it up with previous results and your answer is
2/9 sin(3x) - 2/3 x*cos(3x) + C
woohoo
Thanks alot people i actucally sort of understand now, thanks alot !!!!!!
Thanks peeps !!!!!
One more little question !!!
The question was:
and i put this into :
i have asked my teacher and he told me to leave 2x (-1/3 Cos 3x) and not change it would that be right ?? or do i change it to :
2/9 sin (3x)
176
hello there
this is the answer
there is nothing to change, listen to your teacher, especially if your teacher told you not to change anything why do you want to change it? if you want to change the order of the terms around in the answer feel free to do so because that wont change the answer anyway good luck with it
steven
Another question lol
Sorry to bother you people but i have another question i got to ask if i have done it right, this time is integration by substitution:
integrate 1 / (3x+5) to the power of 4 dx
u = 3x + 5
du/dx = 3
dx = du / 3
integrate 1 / (u to the power of 4) (du / 3)
1/3 integrate 1 / u to the power of 4 du
1/3 integrate u to the power of -4 du
1/3 integrate u to the power of -3 / u to the power of -3 + C
-1/9 1 / u to the power of 3 + C
-1/9 1 / (3x + 5) to the power of 4 + C
Is this right ?????
Thanks
176
hello Tino
Oh your not bothering us, no need to apologise we are here to help each other and we are happy to have you as part of our forum :) now let us look at your question
steven
Thanks
Thanks, sorry i will learn to type in different format next time so it will be easier for all of you to read and understand.
:approve:
176
this is how i would do it
integrate 1/(3x+5)^4 dx
let u = 3x+5
du/dx=3
du=du/3
dx=du/3 now substitute this and u = 3x+5 into the integration question to get
1/3 integrate 1/u^4 du
1/3*-1/3*1/u^3+C=-1/9*1/(3x+5)^3+C=-1/9(3x+5)^3+C
watch very carefully how i have done it
steven
cronxeh
[tex] \int \frac{1}{(3x+5)^4} dx = [/tex] [tex]\frac{-1}{9(3x+5)^3}[/tex]
Related Threads for: Integration by parts HELP
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
