• Support PF! Buy your school textbooks, materials and every day products Here!
Integration by parts ln(2x+1)
  • Thread starter MHrtz
Take the integral of the following:
1. ln(2x+1)
2. arctan4x
3. ecosxsin2x evaluated from 0 to pi
1. took the derivative of ln(2x+1) and integrated dx. my solution was:
xln(2x +1) + x + [(2x + 1)-2]/2 + C
The books answer was:
(1/2)(2x + 1)ln(2x + 1) - x + C
2. took the derivative of arctan4x and the integrated dx. My solution was:
xarctan4x - (1+ x2)-2 + C
xarctan 4x - (1/8)ln(1 + 16x2) + C
3. I derived sin2x and integrated ecosx but I got something more complex than what I started with.
Answers and Replies
5,288
1. ln(2x+1)
2. arctan4x
I'm not sure that you understand how integration by parts works. When you do this, you get a product of functions (xln(2x + 1) in this case) and another integral, that should be simpler than the one you started with.
[tex]\int \ln{(2x+1)}dx = x~ln(2x + 1) - \int \frac{2xdx}{2x + 1}[/tex]
You didn't mention getting the integral on the right. If you did get it, I don't think you integrated correctly.
I did get the integral on the right then I made u = 2x + 1, du = 2 dx, and (u - 1) = 2x
Char. Limit
For the third integral, start by changing sin(2x) to 2 sin(x) cos(x) using the double angle rule, then substitute u=cos(x). Only then should you integrate by parts.
If u = cosx then does this mean that dv = 2sinx ecosx dx?
Char. Limit
No, I mean make a u-substitution first. THEN integrate by parts. Use s=cos(x) if you're too used to using u and dv for integration by parts.
5,288
So it looks like you are doing an ordinary substitution. There are two other approaches that are more direct.
1. Rewrite the integrand of the integral on the right like so.
[tex]\frac{2x}{2x + 1} = \frac{2x + 1 - 1}{2x + 1} = \frac{2x + 1}{2x + 1} - \frac{1}{2x + 1} = 1 - \frac{1}{2x + 1}[/tex]
So
[tex]-\int \frac{2xdx}{2x+1} = -\int\left(1 - \frac{1}{2x + 1} \right)dx[/tex]
This is an easy integral.
2. Use polynomial division to divide 2x by 2x + 1. This results in 1 - 1/(2x + 1), the same as above.
5,288
Yes. When you integrate dv you will get -ecosx. Integration by parts results in the following:
[tex]-cosx~e^{cosx} - \int e^{cosx}~sinx~dx[/tex]
The integral on the right can be done with a substitution.
Char. Limit
Oh right... I guess you could do integration by parts that way too.
I tried your method for the third integral but still got a wrong answer. I used a calculator and determined that the actual answer was e - (1/e). Here's what I did:
s = cosx
ds = -sinx dx
[itex]\int[/itex]2sinxcosxecosxdx = -2[itex]\int[/itex]sesds
u = s
du = ds
dv = esds
v = es
-2ses - [itex]\int[/itex]esds
-2cosxecosx + [itex]\int[/itex]sinxecosx dx
Let me know if that much is right so I can continue.
5,288
s = cosx
ds = -sinx dx
u = s
du = ds
dv = esds
v = es
In the line above, the + in the middle should be =. Also, there should be a coefficient of 2 on the integral at the right. These two errors would cause you to get an incorrect answer.
-2cosxecosx - 2[itex]\int[/itex]sinxecosx dx
u = cosx
du = -sinx dx
2[itex]\int[/itex]eudu
-2cosxecosx + 2eu
[-2cosxecosx + 2ecosx] evaulated from 0 to pi
What about this?
5,288
I get 4/e, which is the same as what wolframalpha gets. The value you reported earlier (e - 1/e) is apparently incorrect.
Ok. So I get 4/e now as my final answer. My mistake was that I dropped a negative while carrying out my evaluation. For the first integral I tried a different attempt but the answer is still off:
u = ln(2x+1)
du = 2/(2x+1) dx
dv = dx
v = x
xln(2x+1) - [itex]\int[/itex] 2x/(2x+1) dx
u = 2x + 1
du = 2 dx
x = (u-1)
xln(2x+1) - (1/2)[itex]\int[/itex](u-1)/u du
xln(2x+1) - (1/2)[itex]\int[/itex]1 - u-1 du
xln(2x+1) - (1/2)x - (1/2)ln(2x + 1) + C
Can this be simplified to look like the book's answer or am I still integrating incorrectly?
5,288
u = ln(2x+1)
du = 2/(2x+1) dx
dv = dx
v = x
u = 2x + 1
du = 2 dx
x = (u-1)
The line above is wrong. u = 2x + 1 ==> x = (u - 1)/2
No and yes. See above.
Char. Limit
u = ln(2x+1)
du = 2/(2x+1) dx
dv = dx
v = x
u = 2x + 1
du = 2 dx
x = (u-1)
It's actually 2x = (u - 1). Which still gives the correct integral in the next line, I believe.
[itex]x ln(2x+1) - \frac{1}{2}\int\frac{u-1}{u} du[/itex]
Related Threads on Integration by parts ln(2x+1)
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
9K
  • Last Post
