Integration by parts problem
  1. Dec 26, 2011 #1
    Use integration by parts to derive the formula:
    [tex]\int (a^2 - x^2)^n dx = \frac{x(a^2-x^2)^n}{2n+1} + \frac{2a^2n}{2n+1}\int \frac{(a^2 - x^2)^n}{(a^2 - x^2)} dx + C [/tex]
    2. Relevant equations
    Integration by parts general formula
    ∫udv = uv - ∫vdu
    3. The attempt at a solution
    I tried the following:
    [tex] u = (a^2 - x^2)^n, dv = 1 [/tex]
    This gave me another integral, as expected. However, further applications of integration by parts didn't give me the right answer. I am still looking for other terms for 'u' and 'dv'.
  3. Dec 26, 2011 #2
    SammyS
    Staff Emeritus
    What did you get when you used [itex] u = (a^2 - x^2)^n,\ \ dv = 1\,?[/itex]
    There's a bit of a trick involved in getting to the correct solution.
  4. Dec 26, 2011 #3
    Well, it became this:
    [tex]x(a^2 - x^2) + \int \frac{2nx(a^2 - x^2)^ndx}{(a^2-x^2)}[/tex] So I took 2n out of the integral, as it's constant, then, I've tried using: u = (a^2 - x^2)^(n-1) and dv = x, which will result in another integral: ∫nx^3(a^2 - x^2)^(n-2)dx, so this way will just generate (n-k) integrals, while that choosing u = x and dv = (a^2 - x^2)^(n-1), creates: ∫∫(a^2 - x^2)^(n-1)dxdx. (I took out the (uv) part just to show that both my ways weren't correct). Sorry if there is anything wrong. I did these calculations really quick.
  5. Dec 26, 2011 #4
    SammyS
    Staff Emeritus
    That should be [itex]\displaystyle x(a^2 - x^2)^n+\int \frac{2nx^2(a^2 - x^2)^ndx}{(a^2-x^2)}\,,[/itex] which can be written: [itex]\displaystyle x(a^2 - x^2)^n+2n\int x^2(a^2 - x^2)^{n-1}dx\,.[/itex]
    Added in Edit: (I pressed save message instead of preview.)
    Expand the factor of x2 in the integral as [itex]\ -\{(a^2-x^2)-a^2\}\,.[/itex]
  6. Dec 26, 2011 #5
    Sorry, forgot to put the 'n' exponent. I would put the (n-1) exponent, but tex shows it wrongly... [tex]x^(n-1)[/tex]
    So, where should I expand the factor? The initial integral or the one after the integration by parts? Sorry, for not understanding, but in what does expanding the factor will help?
  7. Dec 26, 2011 #6
    SammyS
    Staff Emeritus
    To get tex to show it correctly enclose it in {}, e.g. (a^2-x^2)^{n-1} .
    In the integral [itex]\displaystyle 2n\int x^2(a^2 - x^2)^{n-1}dx[/itex] there's a factor [itex]x^2[/itex].
    Write that [itex]x^2[/itex] as [itex]\ \ x^2=-\{(a^2-x^2)-a^2\}\,.[/itex] Distribute the (a2-x2)n through that, but don't break up the (a2-x2) . Split into two integrals, one of which is the same as the original.​
    Alternatively:
    Write the original integral as:
    [itex]\displaystyle \int (a^2 - x^2)^n dx=\int\left((a^2-x^2)(a^2-x^2)^{n-1}\right)dx[/itex]
    [itex]\displaystyle =\int\left(a^2(a^2-x^2)^{n-1}\right)dx-\int\left(x^2(a^2-x^2)^{n-1}\right)dx[/itex]​
    Use integration by parts on the second integral on the last line, letting u=x, and dv will be all the rest.
    The integration by parts will include an integral identical to your initial integral. Use algebra to solve for that integral.​
  8. Dec 26, 2011 #7
    SammyS:
    Finally I was able to get it correctly, thank you very much.
