Integrate by Parts: Solve \int e^{x}sinxdx
In summary, the conversation discusses the process of solving an integration problem using integration by parts. The participants go through the steps and realize that the process repeats itself, but not endlessly. They then discuss how to handle the repeating process and come to the conclusion that a constant term must be added at the end.
LadiesMan
96
[SOLVED] Integration by parts
1. Evaluate
[tex]\int e^{x}sinxdx[/tex]
[Hint: Integrate by parts twice.]
I can't seem to get an answer, but by integrating, the process is redundant (repeats itself).
Thanks
Work:
Let u = sin x, therefore du = cosxdx
Let [tex]dv = e^{x}dx[/tex], therefore v = [tex]e^{x}[/tex]
Using Integration by parts in Differential Notation
[tex]\int e^{x}sinxdx = e^{x}sinx - \int e^{x}cosxdx[/tex] <--- See how [tex]\int e^{x}cosxdx[/tex] The process of integration will repeat over and over again.
What am I doing wrong?
Re-type!
Ok, now show some work! You obviously know it's redundant, so show your steps up to when you figured that out.
sorry about that. I'm just getting use to the latex sourcing
One other thing -- have faith! Apply integration by parts on your new integral, then look at the full equation you end up with for your integral; there is something you'll notice. (The process repeats, but not endlessly...)
yes but it ends back to another integral and then another... however using a different trigonometric function (i.e. sin instead of cos, or vice-versa)
Throughout it makes a process of e^x sinx - e^x cosx...(This process repeats over and over again)
Do it once again, and you will end up with your original Integral. From here it's only Algebra, just bring your original Integral to the left side and divide by the constant, and you're done!
what do you mean divide by the constant?
[tex]\int e^{x}sinxdx = e^{x}sinx - e^{x}cosxdx - \int e^{x}sinxdx[/tex]
Oh wait, I get it! =P
[tex]\int e^{x}sinxdx = 1/2 (e^{x}sinx - e^{x}cosxdx)[/tex] But how do we get a C (Constant)?
Just add a +C at the end. No fuss, no hassle.
Congrats!
Ok thanks =). So the C came from previous integrations?
Yes.
1. What is integration by parts?
Integration by parts is a method used in calculus to find the integral of a product of two functions. It is based on the product rule of differentiation and is useful for integrating functions that cannot be solved by simple substitution.
2. How do you use integration by parts?
To use integration by parts, you need to identify the two functions in the integrand - one that can be easily integrated and one that can be easily differentiated. Then, you apply the integration by parts formula: ∫u(x)v'(x) dx = u(x)v(x) - ∫v(x)u'(x) dx.
3. How do you solve \int e^{x}sinxdx using integration by parts?
For \int e^{x}sinxdx, we can let u = sinx and dv = e^{x}dx. Then, du = cosx dx and v = e^{x}. Plugging these values into the integration by parts formula, we get \int e^{x}sinxdx = e^{x}sinx - \int e^{x}cosxdx. We can then repeat the integration by parts process for the remaining integral until we reach a solution.
4. What are the limits of integration in solving \int e^{x}sinxdx?
The limits of integration depend on the specific problem or context in which \int e^{x}sinxdx is being solved. If there are no specified limits, then the integral is indefinite and the solution will include a constant of integration.
5. What are some tips for using integration by parts effectively?
Some tips for using integration by parts effectively include: trying to simplify the integrand as much as possible before applying the formula, choosing u and dv strategically to make the integral easier to solve, and being careful with signs and constants when integrating multiple times. It is also helpful to practice and familiarize oneself with the method through various examples.
