Integration by Parts
the_dialogue
79
Here is a question I'm struggling with. I encountered it in a paper, and although a solution is provided I'm not so sure I understand where they're coming from.
[tex]\int_{r_1}^{r_2} \overline{v}\frac{1}{r}\frac{d}{dr}(r\frac{du}{dr})rdr[/tex]
where [tex]\overline{v}[/tex] is the conjugate of [tex]v[/tex]
I tried using the traditional integration by parts learned in undergraduate calculus courses, but I'm not getting anything close to the solution.
Any help getting started would be appreciated.
Answers and Replies
8,210
I would simplilfy it first before trying to integrate.
[tex]\frac{d}{dr}(r\frac{du}{dr})~=~r\frac{d^2 u}{dr^2} + \frac{du}{dr}[/tex]
Here I'm using the product rule.
Using the differentiated expression above, and doing some other simplification (cancelling the 1/r and r), your first integral becomes
[tex]\int_{r_1}^{r_2} \bar{v}(r\frac{d^2 u}{dr^2} + \frac{du}{dr})dr[/tex]
Now split the above integral into two integrals. That should make the integration a little easier.
the_dialogue
79
That's right -- I got that far. At this point I'm not sure how to go on. I have some trouble understanding the proper notation.
Could someone assist in continuing?
8,210
Is v_bar a constant in the integration or does it depend on r?
the_dialogue
79
V_bar has dependence on r.
vela
Staff Emeritus
Education Advisor
15,513
2,159
What's the expression you're trying to derive?
the_dialogue
79
Well the result should be:
[tex] \left[\overline{v}r\frac{du}{dr}\right]_{r_1}^{r_2}-\left[\overline{r}u\frac{\overline{dv}}{dr}\right]_{r_1}^{r_2}+\int_{r_1}^{r_2}(\overline{\frac{d^2 v}{dr^2}+\frac{1}{r}\frac{dv}{dr})rudr[/tex]
Sorry the latex isn't updating, or at least it hasn't yet. Look at the code to see the rest of the equation...
vela
Staff Emeritus
Education Advisor
15,513
2,159
OK, they integrated by parts twice. The first time, they used
[tex]f=\overline{v} \mbox{ and } dg=\frac{d}{dr}(ru') dr[/tex]
That gets you the first term and the integral of [itex]ru'\overline{v}'[/itex]. For the second integration by parts, they used
[tex]f=r\overline{v}' \mbox{ and } dg=u' dr[/tex]
the_dialogue
79
For the second integration I get:
[tex]\left[\overline{v'}ru\right]_{r_1}^{r_2}-\int_{r_1}^{r_2}(u(\overline{v'}+r\frac{d\overline{v'}}{dr})dr[/tex]
Which is obviously different than what they got:
[tex]-\left[\overline{r}u\frac{\overline{dv}}{dr}\right]_{r_1}^{r_2}+\int_{r_1}^{r_2}(\overline{\frac{d^2 v}{dr^2}+\frac{1}{r}\frac{dv}{dr})rudr[/tex]
vela
Staff Emeritus
Education Advisor
15,513
2,159
Is this what you say they got?
[tex]\int_{r_1}^{r_2} (\overline{\frac{d^2 v}{dr^2}+\frac{1}{r}\frac{dv}{dr}}) ru dr[/tex]
If so, it looks the same to me. Why do you think they're different?
the_dialogue
79
Oh of course. Sorry about that.
Many thanks.
Suggested for: Integration by Parts
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
