Homework Help: Integration by parts
  1. Apr 29, 2013 #1
    trollcast
    Find [itex]\int (2x^4\ln3x)\ dx[/itex]
    2. Relevant equations
    3. The attempt at a solution
    I let u = ln3x and dv/dx = x4 and I've managed to solve it and get an answer of:
    [itex]x^5(\frac{2}{5}\ln(3x) - \frac{1}{45} + c)[/itex]
    Which is really close to the answer from wolfram alpha but the last term should be 2/25 not 1/45?
  3. Apr 29, 2013 #2
    jedishrfu
    Staff: Mentor
    Can you show your intermediate steps?
    What did you get for du?
    what did you get for v?
    and then u*v - integral(vdu) ?
  4. Apr 29, 2013 #3
    SammyS
    Staff Emeritus
    How did you get the 1/45 ?
    The constant of integration should outside of the parentheses .
    ##\displaystyle \ x^5\left(\frac{2}{5}\ln(3x) - \frac{1}{45}\right)+C\ ##
  5. Apr 29, 2013 #4
    trollcast
    [itex]\frac{du}{dx} = \frac{1}{3x}[/itex]
    [itex]v = \frac{x^5}{5}[/itex]
    [itex]uv - \int v\frac{du}{dx} =2( \ln3x * \frac{x^5}{5} - \int(\frac{x^5}{5} * \frac{1}{3x}))[/itex]
  6. Apr 29, 2013 #5
    What is the derivative of ln(3x)?
    Edit: You can either use the chain rule as SammyS pointed out below, or you can use the product property of logs to write ln(3x)=ln3+lnx
  7. Apr 29, 2013 #6
    SammyS
    Staff Emeritus
    Using the chain rule:
    ##\displaystyle \frac{d}{dx}\, \ln(3x)=\frac{3}{3x}##
  8. Apr 29, 2013 #7
    trollcast
    Thanks got it now.
  9. Apr 29, 2013 #8
    SammyS
    Staff Emeritus
    Yes, ln3+lnx makes it even more obvious.
Have something to add?
Draft saved Draft deleted
