Help Solving Integration Problem: mg-u-kv=m*a
  • Thread starter kieran1black2
  • Tags
    Integration
In summary, the trouble is in the integration on the left side (go straight o my answer down the bottom of the page)... please help me.
kieran1black2
23
the trouble is in the integration on the left side (go straight o my answer down the bottom of the page)... please help me...
mg-u-kv=m*a
where (all constant)
m= mass= 3000
g=gravity=10
u=thrust=172000
k=30
v=velocity=variable
a=acceleration=variable
accel=v*dv/ds=dv/dt=a
30000-172000-30v = 3000*v*dv/ds
-142000-30v = 3000*v*dv/ds
-(142000+30v) = 3000*v*dv/ds
142000+30v = -3000*v*dv/ds
(142000+30v)/v*dv = -3000*ds
v/(142000+30v)*dv = -1/3000*ds
and then integrate both sides, this is where my calculus stops
i know the right side (-1/3000*ds) becomes -1/3000s + c
where
s= displacement or position and
c= constant
i have 2 scenarios
when s=0, v=1000
and what i need to find is when v=0 what is s?
so once i integrate the left side i sub those values in.
Your integrand is of the form x/(ax+b).
Write it as (1/a)[(ax+b)/(ax+b)-b/(ax+b)].
1/30((142000+30v)/(142000+30v)-142000/(142000+30v))
like this?
what does this achieve?
like this?
Well integrating functions of the type:
x/(b-x) is pretty hard if you don't rewrite them..
You will after a rewriting get things that has ln(x)-functions as primitive functions.
Have you taken courses in calculus?
nah I am only in grade 12 in australia... i just need som help integrating this so i can solve a "flight" plan of a particle with variable acceleration... if you can help me with this it would be great
if this is true:
how do i then integrate it?
If you can't integrate that, take a day off and read a calculus text before continuing physics.
im only in grade 12... i don't have the time to take a day off or read calulus texts... i just need some one to tel me what to do and how to integrate it
Can you divide (142000+30v) by (142000+30v)?
like this?
Why do you insist on sticking those ugly numbers in, at every opportunity? Try working with the constants/variables you defined; much easier to solve problems this way (and makes troubleshooting a breeze.)
yer you get
(1/30)[(1/-142000)/(142000+30v)]
now what?
What is the equation for solving an integration problem?
The equation for solving an integration problem is mg - u - kv = ma, where m is the mass of the object, g is the acceleration due to gravity, u is the initial velocity, k is the damping constant, and v is the velocity of the object at a given time.
What do each of the variables in the integration equation represent?
m represents the mass of the object, g represents the acceleration due to gravity, u represents the initial velocity of the object, k represents the damping constant, and v represents the velocity of the object at a given time.
What is the purpose of solving an integration problem?
The purpose of solving an integration problem is to determine the position, velocity, or acceleration of an object at a given time, based on the forces acting upon it. This can be useful in understanding the motion of objects in various physical systems.
What are some common applications of integration problems?
Integration problems are commonly used in physics, engineering, and other scientific fields to understand the motion of objects and systems. For example, they can be used to analyze the motion of a pendulum, the trajectory of a projectile, or the movement of a mass on a spring.
What are some tips for solving integration problems?
1. Identify the variables and their meanings in the given problem. 2. Use the appropriate integration technique (such as substitution, integration by parts, or partial fractions) to solve the problem. 3. Use the initial conditions or boundary conditions provided in the problem to determine any unknown constants. 4. Double check your work and make sure the units are consistent. 5. Practice and familiarize yourself with different types of integration problems to improve your problem-solving skills.
