Integration help
  • Thread starter franky2727
how do i integrate (1+Z)/(2-2Z)
Answers and Replies
What have you tried so far?
HallsofIvy
41,847
965
[tex]\int\frac{1+Z}{2- 2Z}dZ= \frac{1}{2}\int\frac{1+Z}{1- Z}dZ[/tex]
Does that help?
and
[tex]\frac{1+ Z}{1- Z}= -1- ?[/tex]
Dick
26,263
619
Try a u substitution. What's the obvious one?
substitute 2-2Z for u? but then ive still got something over something else and still dont get what method to use :S
Defennder
2,591
As HallsOfIvy pointed out, you can just use polynomial long division to decompose the fraction into something more integrable.
Dick
26,263
619
If u=2-2Z then Z=(2-u)/2. Substitute that into 1+Z. Now it's all u's.
Dick said it all. You need to write Z in terms of u, then you need to find dz/du by differentiating that. You substitute everything in and integrate.
HallsofIvy
41,847
965
But you will still have to divide the fraction. Seems simpler just to reduce the original fraction.
If you factor out the 2, sub u = 1-z and z = 1-u, all the work has been done for you. Just seperate the fraction and integrate.
HallsofIvy
41,847
965
And, one more time, why not just "separate the fraction" (by which I assume you mean "divide") without the substitution?
Air
202
If you substitute [itex]u=2-2z[/itex], and you simplify it, you will end up with this at one point:
[itex]-\frac12 \int \left( \frac{2}{u} - \frac12 \right) \ \mathrm{d}u \implies \frac14 \int 1 \ \mathrm{d}u - \int \frac{1}{u} \ \mathrm{d}u[/itex]
Integrate this and remember to substitute [itex]u=2-2z[/itex] in the end to get the final answer.
pps
[tex] u = z-1 [/tex]
[tex] du = dz [/tex]
[tex] z = u + 1 [/tex]
[tex]\frac{1}{2} \int \frac{1+z}{1-z}dz =\frac{1}{-2} \int \frac{1+z}{z-1}dz = [/tex]
[tex]\frac{1}{-2} \left( \int \frac{dz}{z-1} + \int \frac{z}{z-1}dz \right) = [/tex]
[tex]\frac{1}{-2} \left( \int \frac{du}{u} + \int \frac{u + 1}{u} du \right) = [/tex]
[tex]\frac{1}{-2} \left( \int \frac{du}{u} + \int \frac{du}{u} + \int du \right) = [/tex]
Continue from this point.
HallsofIvy
41,847
965
And if you use the fact that [tex]\frac{1+z}{2-2z}= -\frac{1}{2}\left(1+ \frac{1}{1-z}\right)[/tex] you have
[tex]\int \frac{1+z}{2- 2z}dz= -\frac{1}{2}\int (1+ \frac{1}{z-1}dz= -\frac{1}{2}(z+ ln|z-1|)+ C[/tex]
That seems simpler to me.
pps
Your method is indeed much simpler. =)
Dick
26,263
619
I don't think it's MUCH simpler. It's six of one and half a dozen of the other. Neither one is all that complicated. If you ask me. And you don't have to.
That's false though... Just check z=0 the left side gives 1/2, but the right side gives -(1/2)(2)=-1...
Dick
26,263
619
At this point I'm wondering who cares. franky2727 hasn't checked in since the initial post. I guess this thread is just getting a lot of attention because nothing else is going on.
HallsofIvy
41,847
965
Typo: I meant
[tex]-\frac{1}{2}\left(1+ \frac{2}{z-1}\right)[/tex]
Related Threads on Integration help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
