• Support PF! Buy your school textbooks, materials and every day products Here!
Integration Help!
  • Thread starter Pete_01
It's been a while since I've done some of these less common integrals. This is for a physics problem but I need to integrate....
int from 0 to 2sec: (emf^2/R) (1-e^(-Rt/L))
basically integrating voltage*current for an RL circuit.
How do I do this?
Answers and Replies
5,311
Is this the integral?
[tex]\int_0^2 \frac{E^2}{R}(1 - e^{-Rt/L})dt[/tex]
I'm assuming that the only variable is t. Split the integral above into two integrals, the first of which is very easy. For the second integral, use the substitution u = -Rt/L, and du = -R/L dt.
ok so the first integral [tex]\frac{E^2}{R}[/tex] can be pulled out leaving:
[tex]\frac{E^2}{R}\int_0^2 \frac{-E^2}{R}(e^{-Rt/L})dt[/tex]
correct?
can you pull out the other E^2/R and have just:
[tex]-\frac{E^4}{R^2}\int_0^2 (e^{-Rt/L})dt[/tex]
and then by u substitution get:
[tex]-\frac{E^4}{R^2}\int_0^2 (e^{u})du[/tex] ?
Sorry, haven't done these for a lonng while.
eumyang
1,347
correct?
No. You need to split the integrals using
[tex]\int (f(x) - g(x)) dx = \int f(x) dx - \int g(x) dx[/tex]
Distribute the fraction, then split the integral.
69
69
Ok, but in my problem the E and R are constants so can't I take them out?
5,311
If you take out E^2/R first, you will have two terms in the integrand. If you do it that way, I would still recommend splitting the integral into two parts.
Could someone please go step by step and show me how to do this? It's such a small part of the original problem. Thank you
rock.freak667
6,230
31
You have this right?
So let's do as Mark44 said and take out the E2/R. You will be left with
[tex]\frac{E^2}{R} \int_0^2 (1 - e^{-Rt/L})dt[/tex]
Are you able to evaluate this now?
Related Threads on Integration Help!
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
