Integration of a polynomial
In summary, the integral can be rewritten in terms of the d-dimensional spherical coordinates, with the integrand being independent of the generalised angles. By using the Euler beta function identity, the integrals can be solved explicitly, leading to the dependence on d in the final expression.
spaghetti3451
1,344
33
Consider the following integration:
$$\int \frac{d^{4}k}{(2\pi)^{4}}\ \frac{1}{(k^{2}+m^{2})^{\alpha}}=\frac{1}{(4\pi)^{d/2}} \frac{\Gamma\left(\alpha-\frac{d}{2}\right)}{\Gamma(\alpha)}\frac{1}{(m^{2})^{\alpha-d/2}}.$$
How does the dependence on ##d## arise in this integral?
Can someone show the intermediate steps in this integration explicitly?
##d## is the dimensionality - in this case the LHS of your expression should have ##d##s instead of ##4##s in the powers.
The hint is to cast the integral in terms of the ##d##-dimensional spherical coordinates
[tex]
\int \mathrm{d}^{d} V = \int_0^{R} \mathrm{d} r \int^{2\pi}_0 \mathrm{d} \phi_{d-1} \int^{\pi}_0 \mathrm{d} \phi_{d-2} \cdots \int^{\pi}_0 \mathrm{d} \phi_{1} \sin(\phi_{d-2}) \sin^{2}(\phi_{d-1}) \cdots \sin^{d-2} (\phi_1) \,r^{d-1},
[/tex]
noting that the integrand in question is independent of the generalised angles, so that the various angular integrals factorise nicely.
To solve the individual integrals, the following special function (Euler beta function) identity is extremely useful:
[tex]
B(x,y) = 2 \int^{\pi/2}_{0} \mathrm{d}\phi \left(\sin \phi\right)^{2x-1} \left(\cos \phi\right)^{2y-1}
= 2 \int^{\infty}_{0} \mathrm{d}t \frac{t^{2x-1}}{(1+t^2)^{x+y}}
= \frac{\Gamma(x)\,\Gamma(y)}{\Gamma(x+y)}
[/tex]
1. What is the definition of integration of a polynomial?
Integration of a polynomial is a mathematical process that involves finding the antiderivative of a polynomial function. It is the reverse operation of differentiation and is used to calculate the area under the curve of a polynomial function.
2. How do you integrate a polynomial?
To integrate a polynomial, you can use the power rule, which states that you can increase the power of the term by 1 and divide the coefficient by the new power. For example, to integrate x^2, you would increase the power to 3 and divide the coefficient by 3, resulting in x^3/3. You can also use other integration techniques such as substitution and integration by parts.
3. What is the difference between indefinite and definite integration of a polynomial?
Indefinite integration of a polynomial results in a general antiderivative, which includes a constant term. This means that the result is a family of functions rather than a single function. Definite integration, on the other hand, involves calculating the area between a specific interval or limits. This results in a numerical value rather than a function.
4. Can any polynomial be integrated?
Yes, any polynomial function can be integrated. However, the resulting antiderivative may not always be expressed in terms of elementary functions, and in these cases, the integration can only be approximated numerically.
5. What are the applications of integrating a polynomial?
Integration of polynomials has many practical applications in various fields, including physics, engineering, economics, and statistics. It is used to calculate the area under curves, which is essential in finding the velocity, acceleration, and displacement of objects, as well as in calculating probabilities and solving optimization problems.
  • Calculus
