• Support PF! Buy your school textbooks, materials and every day products Here!
Integration of e
  • Thread starter Jovy
[/B]
$$y= \frac 1 {\sqrt{2\pi}}e^{ \frac{- x^2} 2},~y=0,~x=0,~x=1$$
$$Volume=2\pi\int_a^b p(x)h(x)dx$$
I understand how to do the problem, I'm just having trouble integrating.
##h(x)=\frac 1 {\sqrt{2\pi}}e^{ \frac{- x^2} 2},~ p(x)=x##
And you just plug that into the equation.
When you integrate ##\frac 1 {\sqrt{2\pi}}e^{ \frac{- x^2} 2}x## , you use the chain rule right? But first you move the constant ##\frac 1 {\sqrt{2\pi}}## out of the integral next to the ##2\pi##
So it would look like this, ##Volume=2\pi~\frac 1 {\sqrt{2\pi}}~\int_0^1~ xe^{ \frac{- x^2} 2}dx##
I know the anti derivative of ##e^{ \frac{- x^2} 2} is, e^{ \frac{- x^2} 2}## and then you have to do the anti derivative of ## { \frac{- x^2} 2}## as part of the chain rule right? Well, that is where I get stuck.
Answers and Replies
Buzz Bloom
365
Hi Jovy:
I suggest you investigate the substitution u = (x^2)/2, du = x dx
Hope this helps.
Regards,
Buzz
Likes Jovy
Ray Vickson
Dearly Missed
10,706
1,728
[/B]
No, the antiderivative of ##e^{-x^2/2}## is a non-elementary function. In other words, it is not possible to write down the antiderivative in a finite number of terms involving the standard functions. Even if you try to write it down in 1 billion pages of horrible algebra, you cannot do it.
Fortunately, you don't need the antiderivative of ##e^{-x^2/2}##, but of ##x e^{-x^2/2}## instead, and that is a much different story.
5,287
[/B]
What exactly is the problem? All you have given us is an equation in x and y, but you haven't said what it is you're supposed to do?
From your attempt below, it would seem that you're trying to find the volume of a surface of revolution, but there is no clue above that that's what you need to do.
Related Threads on Integration of e
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
29K
  • Last Post
12K
