Integration of Newton equation?
In summary, the integration of Newton's second law requires considering the specific forces acting on a particle and using them to form an ordinary differential equation. This equation can then be solved using integration to obtain the particle's velocity. In some cases, it may be helpful to separate the variables or transform the vector equation into a scalar equation.
WARGREYMONKKTL
54
integration of Newton equation??
Newton's second law is insufficient to describe the motion of a particle. In addition, it requires a value for F, obtained by considering the particular physical entities with which the particle is interacting. For example, a typical resistive force may be modeled as a function of the velocity of the particle, for example:
[tex] \mathbf{F}_{\rm R} = - \lambda \mathbf{v}[/tex]
with λ a positive constant. Once independent relations for each force acting on a particle are available, they can be substituted into Newton's second law to obtain an ordinary differential equation, which is called the equation of motion. Continuing the example, assume that friction is the only force acting on the particle. Then the equation of motion is
[tex] - \lambda \mathbf{v} = m \mathbf{a} = m {d\mathbf{v} \over dt}.[/tex]
This can be integrated to obtain
[tex] \mathbf{v} = \mathbf{v}_0 e^{- \lambda t / m} [/tex]
can some body show me step by step the intergration there?
thanks!
(Edited by HallsofIvy to correct LaTex.)
thanks!
[tex]-\lambda \mathbf{v}= m \frac{d\mathbf{v}}{dt}[/tex]
is what's called a "separable differential equation". We can "separate" the variables as
[tex]-\frac{\lambda}{m} dt= \frac{dv}{v}[/tex]
Integrating both sides:
[tex]-\frac{\lamba}{m}t= ln v+ C[/tex]
[tex]ln v= -\frac{\lambda}{m}t- C[/tex]
[tex]v= C' e^{-\frac{\lambda}{m}t}[/tex]
(C'= e-C)
At t= 0 we have
[tex]v(0)= v_0= C' e^0= C'[/tex]
so
[tex]v(t)= v_0e^{-\frac{\lambda}{m}t}[/tex]
JUst a minor addition to Halls' general procedure:
It is unproblematic to generalize this if the velocity is a vector, rather than a scalar:
Method 1:
Do component-wise integration. This will always work.
Method 2:
For this particular problem, we have straightline motion, since the acceleration vector is parallell to the velocity vector.
Thus, we can always let one coordinate axis coincide with the direction of the velocity vector, i.e, transform our vector equation into a suitable scalar equation.
(C'= e-C)
i dont' get it
i dont' get it
can you show how you get this?:eek: :eek: :eek: :eek:
please show me how you get it?:grumpy:
never mind i get it
anti-ln
thank for your replies!
What is the Newton's equation of motion?
The Newton's equation of motion is a fundamental law in classical mechanics that describes the relationship between the acceleration, mass, and net force acting on an object. It states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
What is the process of integrating Newton's equation?
The process of integrating Newton's equation involves solving for the position, velocity, and acceleration of an object over time by using calculus. This allows us to predict the future motion of an object based on its current state and the forces acting on it.
What are the applications of integrating Newton's equation?
Integrating Newton's equation has numerous applications in various fields of science and engineering. Some examples include predicting the trajectory of a rocket, analyzing the motion of celestial bodies, and designing structures that can withstand different forces.
What are the limitations of integrating Newton's equation?
While Newton's equation is a powerful tool for understanding and predicting motion, it has some limitations. It is only applicable to objects moving at relatively slow speeds and does not account for the effects of relativity and quantum mechanics.
How does integration of Newton's equation relate to other laws of motion?
The integration of Newton's equation is closely related to the other two laws of motion, namely the law of inertia and the law of action and reaction. Together, these laws form the basis of classical mechanics and help us understand the behavior of objects in motion.
