Homework Help: Integration of quotient
  1. Jan 11, 2012 #1
    sharks
    The problem statement, all variables and given/known data
    [tex]\int \frac{r^3-r^5}{\sqrt{1-r^2}}\,.dr[/tex]
    The attempt at a solution
    The presence of [itex]\sqrt{1-r^2}[/itex] suggests that i use the substitution r=sinθ
    The integrand becomes: [tex]\frac{\sin^3\theta-\sin^5\theta}{\cos\theta}[/tex]
    [tex]\frac{dr}{d\theta}=\cos\theta[/tex]
    [tex]\int \frac{r^3-r^5}{\sqrt{1-r^2}}\,.dr=\int \sin^3\theta-\sin^5\theta\,.d\theta=\int\sin^3\theta\,.d\theta-\int\sin^5\theta\,.d\theta[/tex]
    Using the substitution u=cosθ
    [tex]\int\sin^3\theta\,.d\theta=\frac{\cos^3\theta}{3}-\cos\theta[/tex]
    [tex]\int\sin^5\theta\,.d\theta=-\cos \theta+\frac{2\cos^3 \theta}{3}+\frac{\cos^5 \theta}{5}[/tex]
    [tex]\int\sin^3\theta\,.d\theta-\int\sin^5\theta\,.d\theta=-\frac{\cos^3 \theta}{3}-\frac{\cos^5 \theta}{5}[/tex]
  3. Jan 11, 2012 #2
    Consider factoring the middle expression in the bottom line of your above post and then using a trigonometric identity on the resulting expression. Finally, return back from expressing your problem in terms of theta into an expression involving r. The final integral should be elementary.
  4. Jan 11, 2012 #3
    You edited your post. My post above regards factoring the integrand sin^3 - sin^5. From there it should be easy.
  5. Jan 11, 2012 #4
    sharks
    Hi Syrus
    Yes, i'm still trying to work it out, step by step, slowly.
  6. Jan 11, 2012 #5
    hey sharks. i understand. But i think you should consider my post and follow where my hints lead you. From your edited post, looks like you may be going to unneccesary lengths to solve this one!
  7. Jan 11, 2012 #6
    sharks
    OK, so following your guidelines:
    [tex]\int \sin^3\theta-\sin^5\theta\,.d\theta=\int\sin^3 \theta\cos^2 \theta\,.d\theta[/tex]
    Looks like i'll have to use substitution again to solve this.
    Let u=cosθ
    This gives:
    [tex]\frac{\cos^5 \theta}{5}-\frac{\cos^3 \theta}{3}[/tex]
    Then, i have to replace r=sinθ into this integration result... It looks complicated again. I'm not sure i'm doing things right.
  8. Jan 11, 2012 #7
    My apologies sharks, when i attempted the solution I was working too quickly and overlooked the fact that cosθdθ = dr and not dr = cos^2 dθ, as I had.
  9. Jan 11, 2012 #8
    sharks
    It's OK, Syrus. I'll try to figure it out.
    From: [tex]\int\sin^3\theta\,.d\theta-\int\sin^5\theta\,.d\theta=-\frac{\cos^3 \theta}{3}-\frac{\cos^5 \theta}{5}[/tex]
    Reverting the previous substitution, r=sinθ, i get the final answer:
    [tex]\frac{-5(1-r^2)^{\frac{3}{2}}-3(1-r^2)^{\frac{5}{2}}}{15}[/tex]
    This is the correct answer (or maybe they are equivalent, but i doubt it):
    [tex]\frac{-1}{15}(1-r^2)^{\frac{3}{2}}(3r^2 +2)[/tex]
  10. Jan 11, 2012 #9
    Curious3141
    It's easier to simplify algebraically, then integrate by parts (no trig. sub.)
    Start by observing that:
    [tex]\int \frac{r^3-r^5}{\sqrt{1-r^2}}dr = \int \frac{r^3(1-r^2)}{\sqrt{1-r^2}}dr = \int {r^3}{\sqrt{1-r^2}}dr = \int (-\frac{1}{2}r^2)(-2r){\sqrt{1-r^2}}dr[/tex]
    Now put [itex]u = (-\frac{1}{2}r^2)[/itex] and [itex]dv = (-2r){\sqrt{1-r^2}}\,.dr[/itex] into the integration by parts formula [itex]\int udv + \int vdu = uv[/itex] and everything should become clearer.
  11. Jan 11, 2012 #10
    Curious3141
    Not equivalent. Definitely a sign error and at least one coefficient error there. Please try and use the algebraic method, it's much quicker and neater, I assure you.
  12. Jan 11, 2012 #11
    sharks
    Hi Curious3141
    Your method isn't really orthodox but i guess it's better than nothing. So, here are my calculations:
    [tex]\int udv = uv - \int vdu[/tex]
    [tex]uv=\frac{-r^2(1-r^2)^{\frac{3}{2}}}{3}[/tex]
    [tex]\int v.du=\int\frac{-2r}{3}(1-r^2)^{\frac{3}{2}}=\frac{2(1-r^2)^{\frac{5}{2}}}{15}[/tex]
  13. Jan 11, 2012 #12
    Curious3141
    "Orthodox"?! What's that?:rofl: I would say working this out with a direct algebraic method would be considered more "orthodox" than trying complicated trig subs.
    You've worked out [itex]uv[/itex] and [itex]\int vdu[/itex] correctly (except you forgot the dr element in the latter integral).
    But you forgot to integrate v with respect to u to evaluate [itex]\int vdu[/itex]!
    I see you've edited your earlier post. I'm assuming it's a work in progress, so I'll let you finish. Remember to do the full algebraic simplification (gather together common factors) of the final form to make it look like the form you quoted (presumably from the online Wolfram integrator).
  14. Jan 11, 2012 #13
    sharks
    [tex]\int udv = \frac{-r^2(1-r^2)^{\frac{3}{2}}}{3}-\frac{2(1-r^2)^{\frac{5}{2}}}{15}=(1-r^2)^{\frac{3}{2}}.-\frac{3r^2+2}{15}[/tex]
    Finally, the correct answer. I suppose that the standard recognition methods don't apply in this case, as the algebraic manipulation isn't so obvious, at least to me.:redface:
  15. Jan 11, 2012 #14
    Curious3141
    [/PLAIN] [Broken]
    Yes, *I* know what "orthodox" means, thank you :rolleyes:, I'm asking what *you* mean when you say my method isn't "orthodox"?
    The algebraic method is perfectly acceptable and more direct, and, ideally, you should've recognised the pattern (which is fairly obvious, to be honest). You'll probably be able to do it with more practice.
  16. Jan 11, 2012 #15
    sharks
    In my notes, the integration examples are more directly solved, by applying the various integration formulas rather than algebraic manipulation (which seems a bit risky to me as it's like trial and error, especially in tests and exams where time is very limited). After reviewing your method, it is indeed easier. I'll need to practice more and be more confident. Thank you for your help.
  17. Jan 11, 2012 #16
    Curious3141
    No worries, glad to be of help. :smile:
  18. Jan 12, 2012 #17
    tiny-tim
    hi everyone! :smile:
    substituting u = 1 - r2 is easier :wink:
  19. Jan 12, 2012 #18
    Curious3141
    Do you mean [itex]u^2 = 1 - r^2[/itex]? Because that one's dead easy. :biggrin:
    Thanks for spotting it. Sharks - you should definitely use this sub. instead. Practically a four-step solution.
  20. Jan 12, 2012 #19
    tiny-tim
    either will do :biggrin:
  21. Jan 20, 2012 #20
    sharks
    Thanks for the suggestion, tiny-tim. I tested the substitution [itex]u^2 = 1 - r^2[/itex] and got the answer. It is indeed quicker, but since there's no set method for figuring out how to find that lucky substitution... I guess i'll stick to the safe (and more difficult) road.
