Solution for Integral of sin2x/(1+cos^2x) using Substitution Method
  • Thread starter PhizKid
  • Tags
    Integration
It's just a matter of how you choose to express the constant of integration. In summary, the integral of sin2x over 1+cos^2x is equal to -ln(1+cos^2x) + C, or equivalently, -ln(cos(2x) + 3) + C.
PhizKid
477
[itex]\int \frac{sin2x}{1 + cos^{2}x} \textrm{ } dx[/itex]
[itex]\int \frac{sin2x}{1 + cos^{2}x} \textrm{ } dx \\\\
\int \frac{2sinxcosx}{1 + cos^{2}x} \textrm{ } dx \\\\
u = cosx \\\\
-\int \frac{2u}{1 + u^{2}} \textrm{ } du \\\\
w = u^{2} \\\\
-\int \frac{1}{1 + w} \textrm{ } dw \\\\
q = 1 + w \\\\
-\int \frac{1}{q} \textrm{ } dq \\\\
-ln(q) = -ln(1 + w) = -ln(1 + u^{2}) = -ln(1 + cos^{2}x)[/itex]
I don't know what I did wrong
u = cosx \\\\
w = u^{2} \\\\
q = 1 + w \\\\
Your answer is correct, except for the omission of the constant of integration. Which makes all the difference in the world, really.
Here's an easier way to approach the integral. Note that the denominator is, in fact: ##\frac{1}{2}(3 + \cos 2x)##. Can you go from there?
You'll find that the final answer you get using that method is different from your answer by only a constant (##\ln 2##), which means the answers are equivalent.
u = cosx \\\\
w = u^{2} \\\\
q = 1 + w \\\\
What's the derivative of a constant?
I don't see where that denominator is. The solution says it's: -ln(cos(2x) + 3) + C
What is [itex]\displaystyle \ \ -\ln(1 + \cos^{2}x)-(-\ln(\cos(2x) + 3))\ ?[/itex]
Isn't it [itex]ln(\frac{1 + cos^2x}{cos(2x) + 3})[/itex]? But what does [itex]ln(cos(2x) + 3)[/itex] have to do with anything?
Try plotting that function.
It looks like -ln(2)
I get ln(2) .
That's just a constant, so the two answers are equivalent.
1. What is "Integration problem 2"?
"Integration problem 2" refers to a specific integration problem in mathematics. It involves finding the antiderivative or integral of a given function.
2. How is "Integration problem 2" different from other integration problems?
"Integration problem 2" is different from other integration problems because it involves a specific function and set of limits to be integrated, making it unique and requiring a different approach to solve.
3. What are the common methods used to solve "Integration problem 2"?
The most common methods used to solve "Integration problem 2" are substitution, integration by parts, and partial fractions. Other methods may also be used depending on the complexity of the problem.
4. What are some tips for successfully solving "Integration problem 2"?
Some tips for successfully solving "Integration problem 2" include identifying the necessary method to use, carefully applying the steps of that method, and double-checking the solution for accuracy.
5. How can "Integration problem 2" be applied in real-world situations?
Integration problems, including "Integration problem 2", have various real-world applications such as calculating the area under a curve, determining displacement and velocity in physics, and finding the average value of a function in economics and finance.
