Integration problem
  • Thread starter andrew.c
andrew.c
46
A solid rotor ring is made by rotation round the x-axis the area enclosed between the lines y=x+5 and y=2x+7 between the x-values x=0 and x=1.
Find its volume.
n/a
[tex]ytobeintegrated = 2x+7-x-5 \\= x+2\\\int (x=2)dx \\=\left[\frac{x^2}{2}+2x\right](between 1 and 0) \\=3.5 units[/tex]
What next? I think this is only giving me the area in one plane? Do i just multiply by 360 degrees?
Answers and Replies
The Bob
1,119
You cannot simply take away the two functions before integration or multiply by 360 degrees. Also, if you integrate any 2-dimensional, cartesian function without any manipulation you will only get the area under that function. So although your integration is correct (though your solution should be 2.5 cubic units not 3.5), the idea is not.
Try using:
[tex]Volume \ = \ \int_{a}^{b} \pi f(x)^{2} \ dx[/tex]
where f(x) is one of the functions.
What do you think is the next step?
The Bob
Suggested for: Integration problem
  • Last Post
  • Last Post
