Integration Problem
  • Thread starter ACE_99
ACE_99
35
I'm just having a bit of trouble with where to start on this integral.
[tex]\int[1 - (r/0.11)]^1^/^5rdr[/tex]
I've tried using integration by parts, "u" substitution and things like that but I don't seem to be getting anywhere with this. Any help would be greatly appreciated.
Answers and Replies
Gib Z
3,352
Which substitutions did you try? Its obvious the stuff under the radical is giving you trouble, so why not try substituting it away.
ACE_99
35
The first substitution that comes to mind is to let u = (1-(r/0.11)) so du = -1/0.11 dr. Rearranging for dr I get dr = -0.11du. If I sub this into the integral I still have an r in the equation.
From here I rearranged the expression u = (1-(r/0.11)) for r to get r = (1-u)(0.11). If I sub this into the integral I get
I = [tex]\int(u)^1^/^5(1-u)(0.11)(-0.11)du[/tex]
= [tex]\int(u)^1^/^5(1-u)(-0.0121)du[/tex]
It looks a bit better than before but I'm still stumped, hopefully the work I've done up to here is correct.
Gib Z
3,352
It is correct. Now just take the constant outside, and expand the brackets.
ACE_99
35
If I do that then the integral becomes
I = -0.0121[tex]\int (u^1^/^5 - u^6^/^5)[/tex]
= -(0.0121)[(5/6)u6/5 - (5/11)u11/5]
So in order to get a solution I would also need to change the initial limits of integration using u = (1-(r/0.11)). If my initial limits of integration were 0 to 0.11 after subbing them into the equation for u my new limits of integration are from 1 to 0.
Gib Z
3,352
Yes that is correct. If you want to follow convention you'll have to introduce a negative factor and swap the new limits of integration to ensure the upper limit of integration is larger than the lower limit of integration.
Suggested for: Integration Problem
  • Last Post
  • Last Post
  • Last Post
