Integration problem
  • Thread starter Zerkor
find the definite integral [itex]\int\frac{x^3}{\sqrt{x^2 + 1}}[/itex] dx from 0 to 1
This problem is in the integration by parts section .. I chose u = x^3 , and dv=[itex]\frac{1}{\sqrt{x^2 + 1}}[/itex] so v = [itex]\frac{x^4}{4}[/itex] and du = -(x^2 + 1)^([itex]\frac{-3}{2}[/itex]) , so the integral is equal to [itex]\frac{x^4}{4}[/itex] . [itex]\frac{1}{√x^2 + 1}[/itex] - [itex]\int\frac{x^4}{4}[/itex] . -(x^2 + 1)^([itex]\frac{-3}{2}[/itex]) .. and my problem is the integral on the right hand side of the equation; I don't know how to integrate it and I don't know whether if I've chosen the parts correctly or there is a better way of choosing the parts
Answers and Replies
hilbert2
Insights Author
545
How about first doing a change of variables s=x2. Now ds=2xdx and the integrand simplifies considerably.
STEMucator
2,075
140
If the change of variable doesn't float your boat, you could use a trig substitution of ##x = atanθ##.
LCKurtz
Insights Author
770
It isn't the easiest way to work the problem, but if you really want to use integration by parts, try$$
u = x^2,\,dv=\frac x {\sqrt{x^2+1}}$$
SteamKing
Staff Emeritus
12,798
1,670
In the OP, if u = x^3, then du = 3x^2 dx, not that weird expression. This is basic differentiation.
And if dv = dx/SQRT(x^2+1), then v certainly is not equal to (1/4)*x^4.
You should review the formulas for derivatives and simple integrals.
HallsofIvy
41,847
965
You have "u" and "v" confused. With u= x^3, du= 3x^2dx- you differentiated v. With [itex]dv= \frac{1}{\sqrt{x^2+ 1}}[/itex], [itex]v= arctan(x)[/itex]- you integrated u.
A one solve the definite integral
∫x2/√x2+1 dx={z=x2+1,dz=2*x*dx}=
∫(z-1)/(2√z) dz=1/3*z3/2-√z={x=0⇔z=1,x=1⇔z=2}=(2-√2)/3
LCKurtz
Insights Author
770
All these responses and suggestions, and Zerkor never returned to his thread. :frown:
I tried this one and it didn't work .. In the sections I've studied in the previous two days I learned trigonometric substitution and miscellaneous substitution; I think I have to try working this problem with those techniques
Thanks a lot guys for your help and I'm sorry for replying after a long period but I didn't access the forum through those two days :)
SteamKing
Staff Emeritus
12,798
1,670
Without showing your work, we can't say why integration by parts didn't work for you, except you must have made a mistake. IBP does work for this integral, but your earlier postings show that you do not have a grasp on how to apply it correctly.
May be you are right. But I've just worked it using trigonometric substitution using x = tanθ and it worked correctly .. Maybe there exist a way to find it using IBP but it's a hard way and there is no use for it if there is an easier way :)
LCKurtz
Insights Author
770
But since you are learning calculus, don't you think it might be of some value to figure out why it's not working for you?
Related Threads on Integration problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
