1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Integration question, please help!
  1. Aug 8, 2012 #1
    Evaluate the following integral:
    2. Relevant equations
    [tex]\int_{0}^{\frac{\pi }{4}}ln(1+tanx)dx[/tex]
    3. The attempt at a solution
    I tried to split is into ln(1) times ln(tanx) but didnt work.
  3. Aug 8, 2012 #2
    Because you can't split it up like that perhaps?
    Use this identity of integrals: Substituting x=a-t, dx=-dt:
  4. Aug 8, 2012 #3
    can u please show me how to do it, i tried it this way but i messed it up.
  5. Aug 8, 2012 #4
    That is a pretty difficult integral. If you really wrote it down correctly, the best approach is likely to evaluate it numerically.
  6. Aug 8, 2012 #5
    I'll give you a headstart, but you should solve it yourself.
    Applying the result I gave above to your problem, we get that your integral is equal to
    Now, note that [itex]\displaystyle \tan(x)=\frac{\sin(x)}{\cos(x)}[/itex] so that
    This is easily seen to be equal to
    Now, please take it from there.
  7. Aug 8, 2012 #6
    The indefinite integral is in terms of the logarithmic integral function but the definite integral has a solution.
  8. Aug 8, 2012 #7
    Thank u a lot.
    great forum.
  9. Aug 8, 2012 #8
    What does that mean? Do you have the answer??
  10. Aug 8, 2012 #9
    I don't have the answer but thanks to u, i solved it, the answer is pi/4 ln(2)
  11. Aug 8, 2012 #10
    guys, im learning harder integration so can any one give me an example of an extremely difficult integral?
  12. Aug 8, 2012 #11
    Good luck!
  13. Aug 8, 2012 #12
    wow thats a hard one
    do you have so really big, difficult and intimidating integrals that looks almost impossible to solve
  14. Aug 8, 2012 #13
    Discussion here is not really appropriate, I shall send some to you via PM.
  15. Aug 8, 2012 #14
    thank you
    im new here so excuse me please :)
  16. Aug 9, 2012 #15
    Is it? You might want to sketch the integrand and see if your result is reasonable for the area under the curve ;0).
  17. Aug 10, 2012 #16
    Your really close, you probably made a simple arithmetic mistake in your work. The graph of that is very close to a triangle and the area you found wouldn't fit in the bounds of a triangle. That was fun integral though!
  18. Aug 10, 2012 #17
    Ray Vickson
    Wrong. If we let [itex] J = \int_0^{\pi/4} \, \ln(1 + \tan(x))\, dx,[/itex] your claim is that [itex]J = \pi/4\ln(2).[/itex] If you mean [itex]J = (\pi/4) \ln(2) \doteq 0.5443965,[/itex] that is wrong. If you mean [itex] J = \pi/(4 \ln(2)) \doteq 1.1330900,[/itex] that is also wrong. The correct answer is
    [tex] J = \frac{i}{2}\text{dilog}\left(\frac{1+i}{2}\right) - \frac{i}{2}\text{dilog}\left(\frac{1-i}{2}\right) + \frac{\pi \ln(2)}{4} - C,[/tex]
    where C is Catalan's constant
    [tex] C = \sum_{i=0}^{\infty} \frac{(-1)^i}{(2i+1)^2} [/tex]
    [tex] \text{dilog}(w) = \int_1^w \frac{\ln(t)}{1-t} \, dt[/tex]
    and [itex]i = \sqrt{-1}.[/itex] The numerical value of the correct answer is
    [itex]J \doteq 0.27219826.[/itex] (All this courtesy of Maple11).
  19. Aug 10, 2012 #18
    J≐0.27219826 looks like [tex] \frac{\pi}{8}\ln{2}[/tex] which is why I think it likely he made a simple arithmetic mistake.
  20. Aug 10, 2012 #19
    He probably made the same mistake I did when I worked it out and got the same answer as him :blushing: but I did eventually get[tex]\frac{\pi}{8}\ln2[/tex]
