Integration question
  1. Nov 15, 2009 #1
    hi, erm i just want to ask about integration
    lets say for finding area between 2 graphs, on the positive region, we take the integration of upper curve minus the lower curve w.r.t x-axis
    so what about the area under the x-axis (negative part)
    do we take the more negative curve(greater negative w.r.t x-axis, meaning further away from x-axis) minus the less negative curve(less negative w.r.t x-axis, meaning closer to x-axis) or is it the other way round?
    also what will be my integration limits from? like -5 to -3 or -3 to -5 ?
    also is this the same w.r.t y-axis?
    thanks
  3. Nov 15, 2009 #2
    Bigger area minus smaller area will give the positive area. Also limits from -5 to -3 or -3 to -5 is optional.If Integral value from -5 to -3 is positive, then integral from -3 to -5 will be negative. Whatever way you do the integration, if you are finding the area, then take only the positive value
  4. Nov 15, 2009 #3
    also, if lets say, above the x-axis,
    curve A is above curve B w.r.t x-axis, but curve A extends to below the x-axis AND is closer to the x-axis then curve B,
    so what will i have to integrate from?
    i know on top is integrate curve A - B, but do i take the limits of x-values, all the way from the part where the graph is postive, to including the negative graph part?
    or do i have to integrate only the positive part separately, and then integrate the negative by itself?
  5. Nov 15, 2009 #4
    You will have to do separate integration. If you take the limit all the way, then the area that you get will be the area of curve above x axis minus area of curve below x axis. So you should separately take the limits.
    For example, integral f(x)= sin(x) from 0 to 360 degrees is zero. This is because the area of curve above x axis(from 0 to 180) is equal to area of curve below x axis as is clear from its symmetry. The areas get subtracted to give zero as the answer.
  6. Nov 16, 2009 #5
    oh isee...
    so should i take the more negative curve - the less negative curve or the other way round? if i want to find the area of the region bounded by the negative curves.
Loading...
