jullrich
- 4
jullrich said:Homework Statement
: The diagram represents two coherent light sources emitting light of equal intensity and wavelength. The intensity of the light at point P is zero. Which of the following could be the difference in path length taken by the light in traveling from each source to point P?
: the diagram looks like a 3-4-5 triangle with the short side left off and where to two lines cross for a point on the opposite side to be point P. The length of one side is 4.3 cm and the other side is 5.1 cm.
: we know the answer is 1/2 lamda but have no idea how to how solve this ... please help
The intensity of a wave is directly proportional to its wavelength. This means that as the wavelength increases, the intensity also increases.
The intensity of light can affect its perceived color. Higher intensity light tends to appear brighter and more vibrant, while lower intensity light may appear duller and less saturated.
The inverse relationship between intensity and wavelength means that as one increases, the other decreases. This means that as the wavelength increases, the intensity decreases and vice versa.
The wavelength of a wave is inversely proportional to its energy. This means that as the wavelength increases, the energy decreases and vice versa. Intensity is also related to the energy of a wave, as higher intensity waves have more energy than lower intensity waves.
Higher intensity and shorter wavelength light, such as ultraviolet and X-rays, have more energy and can therefore cause more damage to living organisms. Lower intensity and longer wavelength light, such as infrared and radio waves, have less energy and are less likely to cause damage.
