Interaction Picture: Explaining H = H_o + H_int
In summary, the interaction picture focuses on the effects of the interaction Hamiltonian by transforming the states and operators into a format where only the interaction Hamiltonian needs to be considered. This is done by rolling the effects due to the zero-order Hamiltonian into the states and operators, using the formalism described in Tong's notes. This process does not take into account the interaction Hamiltonian, as it is only setting up the problem for later calculations.
creepypasta13
375
So this concept of H = H_o + H_int has been extremely confusing to me. Wikipedia offers the best explanation, but there a couple things that still confuses me
http://en.wikipedia.org/wiki/Interaction_picture
Why is the state vector in the Interacting picture defined as
|[itex]\psi[/itex][itex]_{I}[/itex](t)> = e[itex]^{i H_{O,S}t/h}[/itex]|[itex]\psi[/itex][itex]_{S}[/itex](t)>
instead of
|[itex]\psi[/itex][itex]_{I}[/itex](t)> = e[itex]^{i H_{O,S}t/h+ i H_{1,S}t/h}[/itex]|[itex]\psi[/itex][itex]_{S}[/itex](t)>?
why isn't the schrodinger picture of the perturbation included?
Similary, why isn't the schrodinger picture of the perturbation included for the equation of the Operators in the Interaction picture?
Finally, why does the exponential factor that determines the perturbation Hamiltonian include only a H[itex]_{O,S}[/itex] and not a H[itex]_{1,S}[/itex]
instead of
The key idea here is to bundle up the "usual" time dependence into the state vector, so we can focus on what's different.
If the Hamiltonian were just [itex]H_{0,S}[/itex], we know the state would evolve with the time-dependent phase factor [itex]e^{iH_{0,S}t/\hbar}[/itex]. The point of the interaction picture is to see how adding [itex]H_{I,S}[/itex] to the Hamiltonian changes the situation. So instead of using [itex]|\psi_S(t)\rangle[/itex] as our point of comparison, we compare to what [itex]|\psi_S(t)\rangle[/itex] would have been if it had just evolved according to [itex]H_{0,S}[/itex] only.
1. When do we compare what |[itex]\psi[/itex](t)>[itex]_{S}[/itex] would have been if it had just evolved according to H[itex]_{O,S}[/itex] only?
I will use the equations in David Tong's notes to make things easier:
http://www.damtp.cam.ac.uk/user/tong/qft/three.pdf
So if, in eq 3.9, we use H = H_O + H_int, then the difference between |[itex]\psi[/itex]>[itex]_{H}[/itex] and |[itex]\psi[/itex](t)>[itex]_{I}[/itex] is what we're really interested in? If so, why do none of the textbooks I've looked at ever talk about that? They just proceed with Dyson's formula with |[itex]\psi[/itex](t)>[itex]_{I}[/itex], but not the difference between it and |[itex]\psi[/itex](t)>[itex]_{H}[/itex]2. If we only care what |[itex]\psi[/itex](t)>[itex]_{S}[/itex] would have been if it had just evolved according to H[itex]_{O,S}[/itex] only, then why is it that in eq. 3.13, he includes the H[itex]_{int}[/itex] part in H[itex]_{S}[/itex]? and does NOT include it in the
|[itex]\psi[/itex]>[itex]_{S}[/itex]?
3. So even though it is called the 'INTERACTION' picture, we don't include H[itex]_{int}[/itex] for H? We only look at H[itex]_{O}[/itex]?Regards,
creepypasta13
You seem to be missing the point that the equations (3.11 in Tong's notes) that you are focusing on are just used to transform the states and operators into the proper format for the interaction picture. The actual calculations are then done using the techniques described further on in those notes.
Another way of thinking about it is that the interaction picture is devoted to focusing on the effects of the interaction Hamiltonian, so you just roll the effects due to the zero-order Hamiltonian into the states and operators using the formalism described in 3.11.
I know that eqs 3.11 are being transformed to the format in the interaction picture (IP). I still don't understand. If the IP is focusing on the effects of the H[itex]_{int}[/itex], why is there the factor e[itex]^{iH_{O}t/h}[/itex] instead of, e[itex]^{iH_{Int}t/h}[/itex] ? where H[itex]_{int}[/itex] is the interacting Hamiltonian in the Schrodinger picture (the H[itex]_{1,S}[/itex] in my 1st post)
Think about what you are doing in 3.11 .. you are simply generating the appropriate form of the state vector (and operator) in the interaction picture. Now, think about the Schrodinger picture ... do the state vectors there take the Hamiltonian into account? No ... they are what is acted upon by the Hamiltonian. It is no different in the interaction picture, once you have "formatted" the state vectors and operators according to 3.11.
That's what I said in my last post .. you are "getting rid of" the zero-order Hamiltonian by rolling it into the state vector. That process isn't *supposed* to take into account the interaction Hamiltonian .. it is just setting up the problem so that only the interaction Hamiltonian need be considered in later steps.
I can't really explain it any more clearly than that. You are really just getting hung up on a detail .. I think it will become clear to you if you press on through the notes.
I think I am starting to understand this a little better. For instance, if I substitute
from eq 3.9 to 3.11, we get
|[itex]\psi[/itex](t)>[itex]_{I}[/itex] = e[itex]^{-i(H-H_{O})t}[/itex] | [itex]\psi[/itex](t)>[itex]_{H}[/itex]
which makes sense considering that we want |[itex]\psi[/itex](t)>[itex]_{I}[/itex] to exclude the H[itex]_{O}[/itex] from the total hamiltonian in the Heisenberg picture H[itex]_{O}[/itex]+H[itex]_{I}[/itex] , right?
Similarly, I obtained (H[itex]_{int}[/itex])[itex]_{I}[/itex] = e[itex]^{-it(H-H_{O})}[/itex]H[itex]_{int, H}[/itex]e[itex]^{it(H-H_{O})}[/itex]. This is also time dependent, right? I thought (H[itex]_{int}[/itex])[itex]_{I}[/itex] is supposed to be time dependent in the Interaction picture, so then why are the minus and plus signs in the exponential factors flipped? (In general, when making H time dependent by converting it from the Schrodinger to the Heisenberg representation, we should have e[itex]^{+H}He^{-H}[/itex])
So we say that the Interaction picture is a "HYBRID" of the free and perturbed hamiltonians when in fact we only care about how the state in the "Interaction picture" only gets affected by the perturbed hamiltonian, and not the total hamiltonian. It is called "HYBRID" because the time dependence of states is determined by H_O but the time dependence of operators is determined by H_int, right?
In the Schrodinger picture, all operators are still, and the state vector moves.
In the Heisenberg picture, the operators move, and the state vector stays still.
The interaction picture is conceptually closer to the Heisenberg picture --- if it wasn't for the perturbation, then the state vector would be stationary. We can get this by applying backwards [tex]H_0[/tex] to the Schrodinger state.
you mean eq 3.11? Or do you mean applying the exp(-H_o) factor to both sides of eq 3.11 to get the |[itex]\psi[/itex](t)>[itex]_{S}[/itex] by itself on the right hand side?
1. What is the Interaction Picture?
The Interaction Picture is a mathematical tool used in quantum mechanics to simplify the calculations of time-dependent systems. It separates the Hamiltonian (H) of a system into two parts: the free Hamiltonian (Ho) and the interaction Hamiltonian (Hint). This allows for easier analysis and understanding of the system's dynamics.
2. How is the Interaction Picture different from the Schrödinger Picture?
In the Schrödinger Picture, the state of a system evolves with time and the operators remain fixed. In the Interaction Picture, both the state and operators evolve with time, but the Hamiltonian is split into two parts, making it easier to solve for the time evolution of the state.
3. What does Ho represent in the Interaction Picture?
Ho represents the free Hamiltonian of the system, which includes the kinetic and potential energy terms. It describes the time evolution of the system in the absence of any external forces or interactions.
4. How does the Interaction Picture simplify calculations?
The Interaction Picture simplifies calculations by separating the Hamiltonian into two parts. The free Hamiltonian, Ho, can be solved exactly, while the interaction Hamiltonian, Hint, can be treated as a small perturbation. This allows for the use of perturbation theory to approximate the time evolution of the system.
5. When is the Interaction Picture most useful?
The Interaction Picture is most useful in time-dependent systems where the interaction Hamiltonian is small compared to the free Hamiltonian. It is also helpful when studying systems with time-dependent external forces or interactions, as it allows for a more straightforward analysis of the dynamics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
