Homework Help: Interesting Random Process
  1. Nov 27, 2015 #1
    • Moved from a technical forum, so homework template missing
    Hello,
    So I was asked this question the other day and don't really know how to go about it:
    "Define a random process by:
    Xn+1 = Xn+1 with probability 1/2
    Xn+1 = 1/Xn with probability 1/2
    Given that X0= 100, find the expectation of X10 "
    I've only ever really met random processes like this when you consider equal step random walks and can use characteristic functions. How would I go about solving this problem?
    Any help would be very much appreciated!
  3. Nov 27, 2015 #2
    Maybe we could compute the average of the next step instead of having a tree ? We could also see the average as a fix point of the average recurrence relation.
  4. Nov 27, 2015 #3
    In other words we write $$x_{n+1}=1/2*(x_n+1+1/x_n) $$
    Computing the fix point is not exact for n=10 this would need a computer program but this method gives average at infinity is $$\phi=\frac {1+\sqrt {5}}{2}\approx 1.62$$
    Average at ten using a program gave me 1.59
  5. Nov 27, 2015 #4
    Ray Vickson
    No, that first equation you wrote is false:
    [tex] E \left( \frac{1}{X_n} \right) \neq \frac{1}{E X_n} [/tex]
    For instance,
    [tex] X_1 = \begin{cases} 101 & \Pr = 1/2 \\
    \displaystyle \frac{1}{100} & \Pr = 1/2
    \end{cases}
    [/tex]
    Thus,
    [tex] E X_1 = \frac{1}{2} \left( 101 + \frac{1}{100} \right) = 50.50500000 [/tex]
    so
    [tex] \frac{1}{E X_1} \doteq 0.01980001980 [/tex]
    but
    [tex] E \left( \frac{1}{X_1} \right) = \frac{1}{2} \left( \frac{1}{101} + 100 \right) \doteq 50.00495050
    [/tex]
    Just for interest's sake: what was the nature of the program you used?
    When I do it in Maple 11 I get the following ##E X_n## values:
    [tex] \begin{array}{rl}
    n & EX_n \\
    2 & 50.75497525 \\
    3 & 38.62872549 \\
    4 & 32.59731395 \\
    5 & 26.56027159 \\
    6 & 22.03256118 \\
    7 & 18.26083028 \\
    8 & 15.24344673 \\
    9 & 12.79228905 \\
    10 & 10.81267707 \\
    \end{array}
    [/tex]
    Basically, starting from a sequence ##V_n## of ##X_n## values (which may have repeated values, so each entry has probability ##2^{-n}##), I form two new sequences ##M_{n+1} = [V_n(1)+1, \ldots ,V_n(2^n)+1]## and ##N_{n+1} = [1/V_n(1) , \ldots, 1/V_n(2^n) ]##, then get a new sequence ##V_{n+1}## of ##X_{n+1}## values by concatenating ##M_{n+1}## and ##N_{n+1}##, then sorting the entries from smallest to largest. The sequence ##V_{n+1}## has ##2^{n+1}## entries, but many entries are duplicated, so each individual entry has probability ##2^{-n-1}##. Of course, the sorting step is unnecessary, but makes the results easier to read.
    Maple did all the computations of the ##V_n## in exact rational arithmetic, so roundoff errors are not an issue. However, I let the ##V_n(i)## values be converted to floating-point numbers in the computation of ##EX_n## because the exact rational value of ##EX_n## becomes a ratio of two huge integers when ##n## gets close to 10. In fact, the exact value of ##EX_{10}## is
    [tex] \begin{array}{lcl} E X_{10} &= & \displaystyle\frac{I_{10}}{J_{10}}, \; \text{where}\\
    I_{10} &=& 1469579070445432944325748152877976451732541041634060024\\ &&653347052338236193574669483177095563513720147511715879 \\
    J_{10} &=& 1359126015084446126651435240624997445643066808400449966906136188164565\\
    &&14601326679253516313161435366438748160
    \end{array}
    [/tex]
  6. Nov 27, 2015 #5
    This recurrence relation is not the recurrence relation of the average but the average recurrence relation, it's not intended to be exact.
    I wrote a small C program( with an error, see the next post)
    Code (C):
    #include<stdio.h>
    double avg=0.0;
    void tree(double val, int depth)
       if(depth<10)
         val=val+1.0;
         tree(val, depth+1);
         val=1.0/val;
         tree(val, depth+1);
       else
         avg+=val;
    int main(void)
       int val0=100.0;
       tree(val0,0);
       printf("Avg : %lf\n",avg/1024.0);
  7. Nov 27, 2015 #6
    I discovered an error in the code, it gives avg near 10.8.
    Code (C):
    #include<stdio.h>
    double avg=0.0;
       if(depth<10)
         tree(val+1.0, depth+1);
         tree(1.0/val, depth+1);
       else
         avg+=val;
    int main(void)
       int val0=100.0;
       tree(val0,0);
    It's by making mistakes that I learn.
  8. Nov 27, 2015 #7
    We obtain different results, i surely made a mistake. It builds a tree starting from 100 and using both recurrence relation up to the level then the final result is averaged.
  9. Nov 27, 2015 #8
    I obtain different values, like rounded :
    E7 18....
    E8 15,...
    E9 12,...
  10. Nov 27, 2015 #9
    Ray Vickson
    Actually, we obtain the same results, or close to it. I had made an error in the recursions for ##n = 7## to ##n = 10##, so those results for ##EX_n## were erroneous. They have now been corrected in the post, and I get ##E X_{10} \approx 10.81##, as do you.
  11. Nov 27, 2015 #10
    The question is now if we got to infinity does it converge to phi ?
  12. Nov 27, 2015 #11
    haruspex
    I can show that asymptotically the mean value lies between 2.3 and 3.
  13. Nov 28, 2015 #12
    I'm interested in the proof you have.
  14. Nov 28, 2015 #13
    haruspex
    Whenever the sequence goes <1, the next step is >1. So I considered a subsequence which skips the <1 step. Sometimes that means we get two consecutive terms the same since it might follow the invert rule twice, so I skip the repeats too. This gets me to a sequence
    ##y_{n+1}=y_n+1## with probability 2/3;
    ##=1/y_n+1## with prob 1/3.
    Let the mean of this sequence be ##\mu## and that of its inverse be ##\nu##. We obtain ##\mu=3+\nu##.
    Since each term >1, 1>##\nu##>=##1/\mu##. Hence ##4>\mu>3.3##.
    Relating this back to the original sequence, the mean of that is ##\frac 23\mu+\frac 13\nu##, and hence equals ##\mu-1##.
  15. Nov 28, 2015 #14
    I don't understand : how do you get $$\mu=3+\nu $$ ?
  16. Nov 28, 2015 #15
    haruspex
    ##\mu=E(y_{n+1})=\frac 23 E(y_n+1)+\frac 13 E(1/y_n+1)=\frac 23(\mu+1)+\frac 13(\nu+1)## etc.
  17. Nov 28, 2015 #16
    It is indeed a deep result.
  18. Nov 29, 2015 #17
    haruspex
    Wasn't happy with the upper bound, so I tried comparing the y sequence with the sequence
    ##z_{n+1}=z_n+1## with prob 2/3; =1 with prob 1/3.
    In a sense which I believe can be made rigorous, this is everywhere less than the y sequence. At least, in the sense that E(z)<E(y) and, more importantly, E(1/z)>E(1/y). E(1/z)=ln(3)/2<0.55, so the average of the original sequence lies between 2.3 and 2.55.
    Update: I generated some 2000-long y sequences starting at 3. The mean of a sequnce rarely fell outside the range 3.3 to 3.55.
Have something to add?
Draft saved Draft deleted
