Homework Help: Interesting Series
  1. Mar 9, 2013 #1
    Is this series convergent or divergent?
    [tex] \sum_{n=2}^{\infty} \frac{1}{(ln(n))^{ln \, ln(n)}} [/tex]
    2. Relevant equations
    [tex] ln(x)<x^a, \, a>0 [/tex]
    3. The attempt at a solution
    I don't see a way to tackle this one other than the comparison test.
    [tex] \sum_{n=2}^{\infty} \frac{1}{(ln(n))^{ln \, ln(n)}} < or > ? [/tex]
    What would I compare this to?
  3. Mar 9, 2013 #2
    Ray Vickson
    Re: LaTeX code: you need }} instead of } to close the \frac command properly. Also, you should write '\ln' instead of 'ln'; 'ln' produces ##ln(n)##, while '\ln' gives ##\ln(n)##.
  4. Mar 9, 2013 #3
    Zondrina
    Slow down and take your hint into consideration.
    For ##a>0##, if ##ln(n) < n^a## then ##(ln(n))^{ln(ln(n))} < (n^a)^{ln(ln(n))}##.
    Reciprocating both sides, you get ##\frac{1}{(ln(n))^{ln(ln(n))}} > \frac{1}{n^{aln(ln(n))}} >## something I will allow you to notice for yourself.
    Then you will have to break down the cases for positive a.... you'll need two cases in total. Pretty sure it was 'p-series' though, not 'a-series' :).
  5. Mar 9, 2013 #4
    I like Serena
    Based on visual inspection it looks as if ##\frac{1}{(\ln n)^{\ln(\ln n)}} > \frac 1 {n^{0.1}} > \frac 1 n## for n sufficiently large.
    The series diverges.
    I don't see how I can match that with your observation though.
    The series ##\dfrac{1}{n^{a\ln(\ln n)}}## converges for any a>0, meaning it won't give conclusive evidence.
Have something to add?
Draft saved Draft deleted
