Homework Help: Interference and Inferometer
  1. Feb 11, 2013 #1
    - why is it that fewer rings are observed when the plates are moved closer together (given wavelength , monochromatic source). What equation shows this relation?
    - Consider a non-monochromatic source, such as a Sodium Lamp, as the distance varies, both patterns change but at differnt rates - one will change at a faster rate than the other - which one changes quicker - the D line with the greater or smaller wavelength? And why is this, again is there an equation to show this relation?
    - As the distance between the plates is changed, the number of rings observed changes also - are there any other observable affects varying with this distance?
    Thanks alot anyone for any assistance !
  3. Feb 12, 2013 #2
    Simon Bridge
    also see: your other thread about this interferometer for the context.
    http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/fabry.html
    Take a look at the geometry panel - when the path difference (length CD) is an integer number of wavelengths you get constructive interference and thus a maxima. CD depends on the angle and how far apart the plates are by simple geometry.
    To understand this - sketch the diagram with different plate separations.
    Again, it is the path difference equation ... the path difference needs to be a whole number of wavelengths.
    Work it out.
    What sort of effect did you have in mind?
