Interior Product: Find from Exterior Product
In summary: So the inverse of the cross product would be just the identity vector. And the inverse of the exterior product would be just the identity vector on the exterior algebra.
joebohr
57
If the interior product is defined as the inverse of the exterior product, then how would I find the interior product of a space given its exterior product?
Sorry, seems a little vague: is this a product of vectors, or the exterior product on a vector
space, i.e., the exterior algebra? Besies, if I understood well, the inner-product takes a pair
of vectors and outputs a number, but the exterior product takes two vectors and gives you another vector. Would you clarify?
I am looking for the general expression for the interior product (not the inner product) of two vectors (x and y) defined on a vector space M. I think this is given in terms of the exterior product and the hodge star, but I'm not sure about the exact expression.
Yes, that's the interior product I was referring to, but wikipedia doesn't give enough info about actually finding an expression for the interior product of two vectors on a vector space and I thought someone here might be able to help.
But the interior product discussed in the link I provided above is between a multilinear map and a vector, not between 2 vectors.
Ok, if there is no interior product for vectors, than what is the inverse of the exterior product? Also, what does the interior product you mentioned represent if it is not this inverse?
Firsty, what do you mean by exterior product of vectors? Usually, given a vector space, the exterior product is a product defined on the exterior algebra of V that assigns to an element of degree p and an element of degree q one of degree p+q. So assuming this is also what you mean by exterior product, then what do you mean by its "inverse"? What properties should such an entity have?
Ah, *ding!*, perhaps you mean so ask somethign like: "given a vector space V, there is the exterior product V x V --> V [itex]\wedge[/itex] V. Given v in V, what is v-1?"
Usually, by v-1 we mean an element such that vv-1=1 in some sense or another. Here, I see no obvious candidate for what the equation vv-1=1 could mean.
Exactly, that's what I'm asking. Sorry if I wasn't clear.
Well, if you are looking for the inverse image of an element of degree two of the canonical map V x V --> V ∧ V, say x∧y, it's just going to be (x,y), (-x,-y), (-y,x) and (y,-x), isn't it? Sorry, this question is still far too vague, can you rephrase it?
Let the exterior product of vectors X and Y be related to the cross product by
X[itex]\times[/itex]Y=[itex]\ast[/itex](X[itex]\wedge[/itex]Y). Then what is the inverse of the mapping [itex]\wedge[/itex]:X[itex]\wedge[/itex]Y[itex]\rightarrow[/itex]C where C is a vector and X, Y, and C belong to the vector space M, say in Euclidean space? Also, using this same logic, what is the inverse of the cross product?
Rephrased, the question is to find the mappings:
[itex]\wedge[/itex][itex]^{-1}[/itex]:X[itex]\wedge[/itex][itex]^{-1}[/itex](X[itex]\wedge[/itex]Y)[itex]\rightarrow[/itex]X
and
[itex]\times[/itex][itex]^{-1}[/itex]:X[itex]\times[/itex][itex]^{-1}[/itex](X[itex]\times[/itex]Y)[itex]\rightarrow[/itex]X
Since we are talking about binary operators for vectors, vv-1 would equal the identity vector for the space M.
1. What is the difference between interior product and exterior product?
The interior product and exterior product are both operations in multilinear algebra. The interior product is a contraction of two vector fields, resulting in a scalar function, while the exterior product is a wedge product of two vector fields, resulting in a bivector field.
2. How do you find the interior product of two vector fields?
To find the interior product of two vector fields, you first take the exterior product of the two vector fields. Then, you contract the resulting bivector field with the metric tensor to obtain a scalar function.
3. Can the interior product be extended to higher dimensions?
Yes, the interior product can be extended to higher dimensions. In three-dimensional space, the interior product of two vector fields results in a scalar function. In four-dimensional space, the interior product of two vector fields results in a vector field, and so on.
4. How is the interior product related to differential forms?
The interior product is closely related to differential forms. It is used to define the Lie derivative of a differential form along a vector field. The interior product also allows for the integration of differential forms over manifolds.
5. What are the practical applications of the interior product?
The interior product has various practical applications in physics and engineering. It is used in the study of electromagnetic fields, general relativity, and fluid mechanics. It is also used in computer graphics and geometric modeling.
  • Topology and Analysis
  • Calculus
