Internal resistance of battery
In summary, the problem involves finding the internal resistance of a battery with an unknown emf. Two cases are given, with different external resistors and terminal potentials. Using the voltage divider equation, V = V_bat [R/(R + R_int)], and the given values, the internal resistance of the battery can be calculated. A SPICE application is recommended for further learning and checking of work.
scholio
160
a battery with unknown internal resistance and open circuit potential (emf) is connected toa 3 ohm external resistor. the terminal potential is found to be 60 volts. when the same battery is connected to a 48 ohm resistor, the terminal potential is 96 volts. what is the internal resistance of the battery?
electric potential V = IR where I is current, R is resistance
current I = epsilon/R where epsilon is emf
I_1 = V_1/R_1 = 60/3 = 20 ampere
I_2 = V_2/R_2 = 96/48 = 2 ampere
now that is as far as i got, to find R internal, do i use a similar formula to R = V/I where V and I are the change in them?
how does the emf come into play?
First, your analysis about the current is wrong--you never took into account the internal resistance of the battery. In actuality, the current is I = V / (R_int + R), where R is the value of the resistor and R_int is the internal resistance of the battery. Anyways, this is the wrong approach.
The key equation is the "voltage divider" equation: V = V_bat [R/(R + R_int)]. In this case, V is the voltage, or potential difference, between a point in the circuit just above the added resistor and the ground. Now, your given two cases but there are two unknowns in each case: (1) the battery's voltage and (2) the internal resistance. Are any of these unknowns constant? If so, what can we do with our two equations obtained from both cases?
I noticed that you posted a lot of questions about circuits. If your willing to learn, and take the time, I recommend downloading a SPICE application--with it you can build circuits for most homework problems and obtain the desired quantity and check your work accordingly. Good luck!
To find the internal resistance of the battery, we can use the formula R = (V_1 - V_2)/(I_1 - I_2), where V_1 and V_2 are the terminal potentials and I_1 and I_2 are the corresponding currents for the two different external resistors. This formula takes into account the change in voltage and current when the external resistance is changed.
The emf of the battery is the maximum potential difference that the battery can provide when there is no external load connected. In this case, the emf is not directly used to calculate the internal resistance, but it is important to keep in mind as it is a measure of the battery's ability to generate an electric current.
In summary, to find the internal resistance of the battery, we can use the formula R = (V_1 - V_2)/(I_1 - I_2) and the emf is a measure of the battery's ability to generate an electric current.
What is internal resistance of a battery?
Internal resistance of a battery refers to the resistance within the battery itself that limits the flow of electric current. It is caused by the resistance of the battery's materials and the movement of ions within the battery.
Why is internal resistance of a battery important?
The internal resistance of a battery is important because it affects the performance and lifespan of the battery. A higher internal resistance means that the battery will have a harder time supplying the needed current, resulting in a decrease in performance and a shorter lifespan.
How can internal resistance of a battery be measured?
Internal resistance of a battery can be measured by using a multimeter and performing a voltage drop test. This involves measuring the battery's voltage with and without a load, and then using Ohm's law to calculate the internal resistance.
What factors affect the internal resistance of a battery?
The internal resistance of a battery can be affected by various factors, including the type of battery, its age, temperature, and the amount of current being drawn from it. Higher temperatures and older batteries tend to have higher internal resistance.
How can internal resistance of a battery be reduced?
Internal resistance of a battery can be reduced by using a larger battery with a lower internal resistance, using multiple batteries in parallel to distribute the load, and keeping the battery at a moderate temperature. Regularly charging and maintaining the battery can also help reduce its internal resistance.
12K
