Interpolation method
  • Thread starter danutz
hi i need some help with a problem i'm dealing with
i have a text file of this format
01 08 2002 12 45 26.7
01 08 2002 13 00 27.8
01 08 2002 13 15 27.0
01 08 2002 13 30 28.2
the last being the temperature and i need to interpolate some missing elements using not only the values before and after that elem but also the previous and next day temperatures (meaning if i wanted to interpolate the second row i would need to use the 1st the third and the values at 13:00 in the previous and next day for example) i would really appreciate if someone could tell me which method to use
ps:i used a polynomial interpolation so far
21,992
3,273
Hi danutz! :smile:
Because the solution must be periodic, I guess that trigonometric interpolation could give you something good: http://en.wikipedia.org/wiki/Trigonometric_interpolation
But note, if you use the sine functions, then you will be periodic with period [itex]2\pi[/itex]. If you want to be periodic with period T (for example, 24h), then you will have to use
[tex]f(x)=\sin(\frac{2\pi}{T}x)[/tex]
instead of the sine.
thanks i looked through it but my function won't be a periodic function but one that has somehow random values so it cannot be defined like f(x)=...
i need a method that doesn't interpolate only by the interp polynomial but also by some other values(the temperatures in other days at the same hour) i think it's more like having more than one function and for interpolating f(x0) i need g(x0) and h(x0) and f(points i use to make the polynomial interpolation, x1 x2 ....)
or is it ok to make the polyn interpolation, obtain an f(x0) and just to make some calculus like 3/4f(x0)+ (h(x0)+g(x0))/2/4??
Related Threads for: Interpolation method
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
Hot Threads
